Oil change - why the difference?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Tramp, Feb 7, 2008.
  1. The Tramp
    The Tramp Italian Prius Expert
    369
    45
    Turin, Italy
    2020 Prius PHV
    Reading this forum I was pretty shocked with your oil changes:
    US policy states 3000 - 5000 miles for regular oil, 5000-8000 miles for synth oil.
    The same car, in Europe, do oil changes every 10000 miles, and that's a semi-synth 10W40. With synth, people change oil every 20000 miles.
    Yet cars go on just as in the EU: my old Fiat (diesel) went on for 200.000 miles with a regular oil change every 20.000 miles.
    Now, apart the classic argument regarding costs etc, there should be another aspect that should touch all you Prii owner: oil change is polluting - it needs oil to be made, it is a major polluter when discherged.
    Why change oils so often?
  2. richard schumacher
    7,664
    1,043
    United States
    US oil quality standards are poorer than those in Europe, and Toyota spent a lot of money in the 1990s replacing V6 engines damaged by "sludging".
    Where does Toyota state that US drivers may go 8000 miles between changes if synthetic oil is used? That would be welcome.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Because we are stupid and don't care much about the environment. It's a typical U.S. view on anything: More is better, and too much is perfect. The short oil change interval is historical, back when oil and engines were not as good. It also comes from the litigious nature of the U.S. consumer. No car company wants to be blamed for recommending too long of an oil change interval. There is no down side to Toyota for recommending a short oil change interval, but there is a risk to going to long. This way they avoid a law suite and their dealers get to make more money on service that isn't really needed.
    Tom
  4. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Majority of certified auto mechanics that I know who had replaced rod bearings on vehicles recommend changing oil at specified intervals for the vehicle to prevent such damage and prolong engine life. For a diesel engine, I would expect at least 300K to 400K on the engine or perhaps more. :rolleyes:
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Oh please, you can expect just as long a life out of EU cars running 24 month, 30,000 mile oil change intervals!
    The magic, wonderful API allows an oil to "pass" if: it thickens +100% in use, allows cold stuck rings, cold black sludge, and a Gellation Index of 12, running an interval ONE THIRD of the ACEA EU test regime
    Go to the EU and mention you want to change your oil every 3,000 miles, they'll have you committed
  6. Rest
    Rest Active Member
    1,210
    CA
    I totally agree! Engines and oils are much better than they were back in the 60's, when the 3,000 mile oil change rule came about. Now 3,000 mile oil changes are just a waste of money and good oil. If you want to change something, fearing dirty oil, then change out the oil filter every 3,000 miles.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Selling oil is profitable!
  8. sweetguy
    sweetguy Junior Member
    85
    Maine
    Can you change the filter in the Prius without changing the oil? Is it easy to change the oil in the Prius?
    Many years ago, Consumer Reports did a study of NYC taxi cabs and measured engine wear when oil was changed every 3000 versus every 7500 miles. They found no difference. Given advances in oil and engines, even 7500 is probably too soon. But I would go with the manual just to be safe.
  9. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    I should stop responding to Prius engine oil threads, but it is my personal oil addicition!
    Prius was introduced in the US with 7500 mile oil change intervals on American (low-spec) engine oils. Later, Toyota changed their whole fleet OC interval to 5k based on sludge problems with a different engine.
    It may be that 5k is too short for the Prius engine even with low-spec oils. However, shops that change oil may use (even worse) barrel stuff. Ask Jayman about that!
    Perhaps a more sensible approach is to use American synthetic oils, because they won't varnish your engine. If you do use synthetic, you can consider longer OC intervals. Based on many used oil analyses, group IV or hydrocracked group III "synthetics" are probably OK in Prius for 10k miles.
    The best is if you can pay $30 for UOA in *your Prius*. Then you'll know. TBN will probably be getting low after 10k. If you have UOA for your car, you will be able to determine an optimal OC interval and will know if anything else is going wrong in there.
    DIY oil changes with synthetic and UOA cost less than dealer-changes with conventional oil, and provide you with valuable info as well.
    Sweetguy if you want to change the filter "early", cut the top off a right sized soda bottle, and use it as a twister-offer. It will catch most of the mess.
    Filling new oil filters with new oil before installing them is good practice.
  10. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    You can also use an oversized oil filter.
    I know that the Purolater PL-20195 fits, I think that the mobil one M-203 fits as well. Compared to the stock filter, these are both huge.
  11. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Maybe someone should start a European Motor Oil inmport business.
  12. kohnen
    317
    58
    Fullerton CA
    I use Mobil 1 EP 5w-30.
    American synthetic to European specs.
  13. The Tramp
    369
    45
    Turin, Italy
    2020 Prius PHV
    and you change oil every 3000 miles or every 10000 miles?
    How much is oil over there?
    Here it varies between 8€ litre and 24€ litre. (depending on quality)
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    No need to. Locally, at Canadian Tire, they sell Castrol Syntec 0W-30. I'm not too impressed with the rest of the Syntec line, but the 0W-30 is actually made in Germany. It meets the very demanding ACEA A3/B3/B4 specs. Same price as the other Syntec oils, $8 a litre
    A Canadian Tire subsidiary, Parts Source, carries Mobil 1 0W-40 European Car Formula for the same price as regular Mobil 1, around $8 a litre. This oil meets a long list of ACEA and builder approvals for the EU 24 month/50,000 km drain intervals
    Mobil 1 0W-40
    As far as I can tell, this is the *only* Mobil product sold in North America to meet those standards. Not Mobil 1 EP, not Mobil 1 High Mileage.
    I'm sure there are other products out there that have the same approvals. But the only API rating they have is SM, same as a generic motor oil costing 1/8 as much
    The average motorist will only see the API Starburst and assume all oils are exactly the same. They will get confused by the notion of ACEA and various builder approvals. So why would they pay 5-8 times more for an oil?
    They won't
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Pretty much all the Mobil 1 meet the minimum ACEA A1/B1 spec, which is the lowest spec for a standard 12 month or 10,000 mile interval.
    Some of the Mobil 1 oils, like EP, offer ACEA A1/A5 and B1/B5 specs. This specifically covers extended drains for up to 24 months or 30,000 km. Mobil 1 0W-40 meets the toughest ACEA specs, EP does not.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    I would guess the average Prius driver in North America changes the oil at least every 6 months or 8,000 km. Probably a good number change every 3-6 months or every 5,000 km. Seriously!
    Mobil 1 0W-40 is $8 a litre here. Using an online currency converter, $8 Canadian dollar is 5.32 Euros.
    The environmental fees are quite high in the EU. They are very low or zero here in North America. For example, if I purchase 5 litres of Mobil 1, I will be charged an additional $1 "environmental levy"
  17. The Tramp
    369
    45
    Turin, Italy
    2020 Prius PHV
    S that's why in the EU we double or treble the mileage between oil-change - it's the expensive oil! :D
    Let's charge the USA 100$ per oil change and watch them change oil every 10000 miles, or 20000, if need be.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    American - and Canadian - motorists are so brainwashed I bet they would still change the oil every 5,000-8,000 km, even if the API was disbanded and only ACEA oils were sold
  19. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    1st Oil change, Mobil 1 5W30, 1000 miles, New filter?
    I have a new Prius with 800 miles. I want to send the oil in for analysis and change to Mobil 1 Synthetic soon.
    Should I leave the original oil filter on ? I guess it may hold some old oil. Is it on real tight ?
    I've run Mobil 1 for 20+ years and, even if nothing else, it provides superior protection in cold Canadian winters, IMO.
    I'm planning to get back more into the wrenching I used to do with previous cars, and do all of the regular maintenance myself when possible. I.E. I'll do the fluids and tire swaps, but tire specialists with their special equipment do the balancing etc.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Re: 1st Oil change, Mobil 1 5W30, 1000 miles, New filter?
    I guess I'm a bit confused. Do you intend to change the oil at 800 miles, or just sample it? I left the factory oil in for 8,000 km
    Change the oil and filter together
    There is no need for an early initial change in the Prius. Those operated in the EU run up to 16,000 km before the first oil change.
    The exception is my FJ. For some reason the oil was already badly degraded after only 3,000 km, so I had it changed
