Oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OZ132, Jun 2, 2009.
  1. OZ132
    OZ132 Member
    170
    Northern Indiana
    The manual recommends 0W-20. Mobil I would seem to be the best choice?
    Would like to do the first one myself, probably early, to get the new engine metals out.
    Any advice?
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
  3. Rest
    Rest Active Member
    1,210
    53
    CA
    There is no need to change the oil early on a modern engine and you're just wasting oil and money by doing so.
  4. Mr.Vanvandenburg
    1,046
    356
    2020 Prius Prime
    Check out BITOG, there is all kinds of info. on the "best" oil. Pennzoil Platinum seems to be a favorite over there. You are doing the right thing by changing oil early, and you're correct wanting to get the initial small wear particles out asap. Unless you use a sub micron bypass filter, the only way to get rid of the small stuff is to drain the oil. At 1K miles I could see them in my oil, and have for forty years, not much has changed in terms of cylinder wall precision, required cylinder roughness for oil control, and wear in particles from that roughness, in that time.
  5. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    That makes all sorts of sense as I read it, but I had read (sorry, it is the proverbial "somewhere"!) that with the latest engines using synthetics, it is best NOT to change the oil early. I can't quite get my mind around that warning. Perhaps someone has heard about this and can address it.
  6. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    The one thing the 2010 Prius has in common with the Tundra 5.7, and the new Corolla: a royal PITA cartridge oil filter system that will make what used to be "routine" oil changes, a messy and time consumming adventure
    Not at all DIY friendly, and a lot easier to break parts, especially the plastic cartridge cap. This is probably to ensure continued revenue for the service bays
    There are endless debates about pros/cons of early initial oil changes. I waited the full 8,000 km for the first oil change in my '04 Prius, had no issues. My '07 FJ, the oil failed lab analysis at under 3,500 km, and the rear axle gear oil was already jet black
    Toyota universally lowered their oil change interval to 6 months or 5,000 miles, after the oil sludge class action lawsuit settlement. This is among the shortest normal oil change interval of any mass market vehicle
    However, if something like a Sequoia or Tundra sits on the dealership lot for 12 months, does that mean the dealership gave it 2 oil changes (Every 6 months) to comply with warranty requirements?
    Of course not. They'll claim that over the course of 12 months and 68 miles, starting up the motor and driving 100 ft down the lot wasn't hard on the oil, was probably GOOD for the oil
    But you still have to provide proof of oil changes every 6 months or 5,000 miles
  7. nthach
    nthach New Member
    174
    I've done a 3000 mile oil change on my parent's 2nd gen, and I ran plain jane Quaker State for 2K until the idiot light came on. Changed the filter with a Wix 51394 and 3.5 quarts of PP 5W-30.
    Pennzoil Platinum is a great oil too - cheaper than M1 as well.
  8. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    2010 Prius III with Navi:
    We are approaching 3,000 miles on our new Prius we bought on 051709.
    My wife and I really enjoy this car. Our 1,400 mile plus trip to Reno was very comfortable and averaged 52.7 MPG.
    Now, my main concern is changing the oil. I am not sure on the type of bolts or screws that secure the cover underneath the engine so I can get to the oil drain plug and the oil filter which I understand is not the dirt simple to install screw on type but the replaceable cartridge which is dirty as well as time consuming.
    Also I plan on using only 4 quarts of 0X20 Mobil 1 synthetic oil so as not to overfill.
    If anyone changes their oil on the 2010 before me please post your expierence.
    Thanks
    Alfon
  9. jayman
    13,439
    640
    Winnipeg Manitoba
    Similar to the new Corolla. This is a good writeup from Toyota Nation
    1st rolla oil change + pictures - Toyota Forums :: Toyota Nation
    Nothing like having an oil change become an adventure
  10. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
  11. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I always do an oil/filter change after the first 2,000 - 3,000 miles to get rid of the break in junk.
    Some cars (BMW M5, for example) come with special "break-in" oil--perhaps what you're thinking of regarding not changing oil early.
  12. bobnocal
    bobnocal New Member
    Chico
    I'm lucky. Where I purchased my 2010 the dealer gives free oil and filter changes for life of car, or at least as long as I own it. I used to do half the oil changes myself. But, if it's as time consuming and painful as described I'll just drop it off on my way to work in the morning and have it back at lunch.
  13. jayman
    13,439
    640
    Winnipeg Manitoba
    For giggles, I checked at a local dealership. My recently sold 2004 Prius, filter is $6. Elements for +2009 Corolla, and 2010 Prius, are $10.50
    Good combination. Dealership makes more money on the parts, and will probably have more vehicles serviced as folks realize what a messy PITA the cartridge system is
  14. Patrick Wong
    18,200
    6,472
    Well, let's see what happens as owners gain experience changing the oil cartridge. If you change the oil first thing in the morning after the car has rested overnight (and do not start the engine first,) you may find that no oil will drip out of the cartridge when the cover is removed.
    My HiHy has a sideways mounted canister oil filter and there's no oil to speak off within the filter when I remove it, after the car has rested quietly overnight.
  15. web1b
    web1b Active Member
    817
    52
    Many cars have this now, not just kind of rare cars like M5s.
    There should not be metal shavings and other "break in junk" in a very modern engine. If there is, you have some serious problems that changing the oil won't fix.
  16. stream
    2,977
    452
    Long Island, NY
    Comments in bold below
  17. web1b
    web1b Active Member
    817
    52
    Toyota doesn't recommend an early oil change as part if the scheduled maintenance and they are extremely conservative about oil changes considering the new Prius requires 5K oil changes despite synthetic oil.
    People's personal family traditions on oil changes passed down for generations and posted to independent websites, aren't the manufacturer's recommendation.
  18. stream
    2,977
    452
    Long Island, NY
    I've examined the oil and filter after several initial 2,000 mile services on my cars, and I can tell you there's plenty of break-in junk in there.
    I (and many others) consider it inexpensive insurance. ;)
  19. web1b
    web1b Active Member
    817
    52
    As long as the car doesn't have special break-in oil that's supposed to stay in for some required minimum mileage, I suppose all this is doing is wasting your own time and money and it won't actually hurt anything.
  20. stream
    2,977
    452
    Long Island, NY
    Lighten up.
    I do know what I'm talking about here. ;) Have you ever examined oil or filter, or had an oil analysis done, on a 2,000 mile old car? I have.
