Oil changes leave old oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by etyler88, Dec 23, 2005.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
    Check out this diagram on attached engine pisture. A large quanitity of oil is below the drain level and therefore is not removed at oil changes. The solution would be to use a oil suction device that is inserted down the dipstick tube. Can any one who has used an oil suction device testify to the amount of oil they have removed, is it significantly over four quarts or three and a half factoring in the filter?
  2. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    I don't see the drain on that picture. Where is it? :blink:
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I agree with the above, how are you drawing your conclusions? the drain plug is not shown in this image. From memory the drain plug sits at approximately the lowest point on the oil pan and thus should remove nearly all the oil--discounting residual sticking to the walls/pan.
  4. etyler88
    etyler88 etyler88
    450
    Dover, DE
    The drain plug appears to be on lower left, little yellow nub with a bolt head just below the yellow.
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    that bolt you're pointing out looks more like a casing bolt to me. they don't put drainplugs there.
  6. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    If I'm understanding you right, what you are refering to is one of the bolts holding the oil pan onto the bottom of the block. Also, the engine sits in the car rotated counter clockwise about 15 degrees from what is shown in the drawing. The bottom of the oil pan is parallel to the ground. Here's a corrected graphic[attachmentid=1537]
  7. efusco
    19,891
    1,192
    Nixa, MO
    Yup, that's a bolt to hold the oil pan on...there's one on the opposite side just like it. There's no drain plug shown. Go take a look under your car and note that the plug is, indeed, at a low point on the pan.
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    from the NCF manual a screen grab of the drain plug relationship to the oil pan bottom. notice the depression where the drain plug backup plate is, at most would hold maybe two table spoons of old oil.
  9. etyler88
    etyler88 etyler88
    450
    Dover, DE
    OK thats good news, thanks.
  10. glenk
    glenk Member
    109
    Fairfield, CA
    If this ICE picture is to scale and the true "full" oil level/dipstick notches are pictured then I don't see how a bit higher oil level is going to affect mileage?
    Look how much clearance there is from the top of the oil level and the crankshaft counter weights.
  11. Danny Diesel
    Danny Diesel Junior Member
    38
    To add to the trivality of this persuite see the following.
    The last time I changed the oil, I let the oil drain for one hour and removed the drain pan. I then put a smaller clean pan under the car and let it catch the drips over night. It cought a 1/2 Pint. And it was still dripping.
  12. jeromep
    jeromep Member
    827
    Eastern Washington State
    Thank you for pointing that out. I've have participated in many discussions, not to the improvement of my sanity, regarding oil changes and oil levels. And the slighly higher oil level that you get with a 4 qt. fill isn't going to do a thing to the engine and there is no risk of crank slap, etc. There is plenty of room in the sump for a couple of shot glasses of oil, which is what .3 quart is about equal to.
    Oh well, I'm kind of glad the oil change discussions have passed. They were getting kind of nasty.
  13. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    It's a legitimate concern. Recently I read that Toyota had a design problem with just this thing, on 4-cyl. engines, the net effect being that a quantity (don't know exactly how much) of oil would sit below the drain plug and result in a sludge buildup, which in turn would lead to premature disintegration of the engine. It got to the lawsuit stage before they settled with many owners. I can probably locate those details if requested.
    Geez, I didn't know that our combustion chambers had the Oblique Squish, did you?
  14. galaxee
    9,810
    465
    MD
    techs still fight amongst each other to get the warranty sludged-engine rebuild jobs where DH works...
    i forget how the whole thing went down, but eventually toyota just took care of all of them under warranty.
  15. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    Well, one nice thing about PC is that people who didn't know anything about their old car...and didn't care...now are starting to learn. Learning is always good.
    But etyler...if you don't go in with a squeegee, you are ALWAYS gonna have old oil. LOL
  16. kaptaink
    kaptaink Junior Member
    52
    South Western NY
    Changed the oil today . . . took out just as much as went in.
  17. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Is that a Oil Gobbling E.T. in the engine?
  18. naterprius
    naterprius Senior Member
    1,843
    You guys, change your oil often, 5000 miles, use a Toyota Filter, change your air filter every 15,000, and you won't have a sludge problem.
    The "famous" sludge issue is with V6's, the fours have exhibited fewer problems.
    Nate
  19. galaxee
    9,810
    465
    MD
    the sludging issue was a design issue, however it was not because of oil remaining in the system. it was because of an operating temperature differential issue between the block and the head. the difference in temperature caused moisture to remain in the oil on vehicles that take mostly short trips and that moisture caused the sludging that blocked oil passages and you know the rest.
  20. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i have always had my oil changed at Toyota of Olympia and it has never been as much as a drop over. the guy who changes it programs the make model and year of car into a computer and the exact amount is dispensed. all but a little is poured in, then the level is checked and topped off if necessary.
    the days of opening separate cans of oil are long gone at my dealer
