Oil changes
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fberger, Feb 7, 2012.
  1. fberger
    fberger Junior Member
    66
    VA USA
    Will the PHV be smart about oil changes requirements?
    For owners driving a majority of miles in EV mode, I would expect very few oil changes to be necessary. But how can that be determined? Will the onboard computer keep track of ICE miles driven and turn on the maintenance light only after 10,000 ice miles?
  2. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    10K ICE miles?! How many miles do you go between oil changes on a Generation 3 Prius?
  3. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    10K miles on a Gen 3
  4. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    10k.
  5. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I go 5K, but Toyota says you can go 10K.
  6. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    Yes, Gen 3 with synthetic oil is 10K, I suspect the PiP will be exactly the same, regardless of how many of them happen to be "EV" miles.
  7. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    Why wouldn't that matter? If you drive a lot and mostly use EV (ICE not turning), why should the oil need to be changed?
  8. mitch672
    1,077
    197
    Randolph, MA
    Because its already at 10,000 miles, and the engine is going to run, if you need heat or AC most likely, also I doubt the PiP will track Pure EV versus blended mileage on separate odometers. The PiP is a hybrid, it is NOT an EV
  9. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Of course it tracks EV percentage against the HV. We've seen multiple videos showing it.
    Oil changes should apply only when the HV mode reaches 10.000 miles driven.
    Edit: Here you go...
  10. moolman
    moolman Member
    142
    16
    Plenty of oil analysis on BITOG show that 10K is good and will protect your engine. Oil analysis is the undisputed way to tell when the best time to change oil is and at 10K the oil is still good.
  11. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    The first two years or 25000 miles are part of the included free maintenance anyway, right?
    EVO 4G ?.
  12. Trollbait
    11,515
    Why doesn't Toyota just license GM's oil life monitoring system? It's nearly as good as using oil analysis to determine when to change the oil. :rolleyes:
  13. oldasdust
    oldasdust Member
    356
    47
    illinois
    Do what you want but if you go over 10k on oil changes warranty can be void. Also if you don't even use 0-20 synthetic could be void. It would be up to Toyota, why would you take that chance ?
    douglasjre likes this.
  14. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    First the confession-- I changed my oil at 98,000 miles. Last change was 16 months ago at 80,000 miles. I always do my own, except for that previous one since it was at a garage due to cracked filter holder. That mechanic over-filled, about 3/4" high on the dip stick. I did not add any oil in between and it was right at the full mark when I changed. Not much usage there! About 1/3 of those miles were EV. I generally change right at 10,000 mile, EV/ICE combined.
  15. ChapmanF
    15,494
    While that post is a decade old, it's a misstatement to say that without saying the rest. As often reminded on PriusChat, when you look in the Gen 3 Warranty and Maintenance Guide, you see a 5,000 mile/6 month interval if your driving hits any of several criteria, or a 10,000 mile/12 month interval otherwise.
    You can look at that as a 10,000 mile OCI that changes to 5,000 miles if your answer is yes to any of those driving questions.
    That's completely equivalent to saying the recommendation is 5,000 miles unless you can truthfully answer no to all of the questions.
    That's reflected in the built-in reminder, which comes on every 5,000 miles.
  16. bisco
    49,399
    have you cleaned the egr circuit yet?
  17. douglasjre
    douglasjre Senior Member
    1,858
    647
    Orlando, FL
    Change it at 5k anyway. Oil analysis won't show you the damage you've done to the rings by getting them stuck
  18. PA Prius
    754
    241
    SE Pennsylvania
    I have not. What is the connection?
  19. Mendel Leisk
    38,657
    Just a very good idea at your miles. See first link in my signature for DIY info.
  20. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Monument, Colorado USA
    Ice or Hybrid, all of our vehicles get engine oil changes every 6-months or 5,000 miles whichever comes first. Not one of our vehicles burns oil or has any issues. (Oldest is a 2008 Corolla, which I just serviced this weekend, and engine looks new with 147,000 miles on her....the outcoming oil didn't even look that dark, which is a good sign.)
    The vast majority of cars do not fit into the 10,000 oil changes category so why risk it?
    drash likes this.
