Oil changes
Discussion in 'Gen 2 Prius Main Forum' started by maggieddd, Oct 17, 2005.
  1. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    I had my first oil change at about 4600 miles. I soon will need another oil change and was thinking of going when I hit about 10000 miles. Would this affect my warranty? They put a stamp in your passport and write down the milage. If it came down to it, could Toyota refuse in warranty repairs stating that I didn't have my oil changed at specified intervals?
  2. aaf709
    3,862
    2022 Prius Prime
    It sounds to me like you're in the ballpark with 4600 and 10000. As long as you have proof of the work it should be fine. The proof should include any that you don't do at the agency.
  3. davedog
    davedog Member
    403
    SF Bay Area, CA USA
    i change my own oil. i'd suggest bringing in your own oil & filter ... or the "shop" might use less-than-par quality!
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I think if they were even the slightest bit nitpicking they still couldn't say anything till went over the 10,600 mi. mark. That's the point you could argue that 5k changes to 6k in between changes.
  5. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    This is sort of like waiting until the last PIP is blinking before you decide to fill up the gas tank. Pushing the limits of recommended maintenance intervals is inadvisable especially with a highly technical machine like the Prius.
  6. DanP
    DanP Member
    256
    He's talking about motor oil--not hacking the software or powering a microwave oven in the glove box. Wait until 10,000 if you like. It's not going to make any difference.
  7. bozebuurman
    bozebuurman New Member
    The Netherlands
    In Holland You have to change oil every 8.000 miles (15.000 km). I think the Prius has the same motor in Europe and in the USA.
  8. 3c3
    3c3 Junior Member
    92
    Silicon Valley, CA
    I should move to Holland and open an oil-change business. :p
  9. PeteB
    PeteB PeteB
    23
    Norfolk, UK
    In the UK it's 10,000 miles or 12 months, which ever comes first.
    PeteB
    Luton UK
  10. maggieddd
    2,090
    Boston
    thanks, but did you read my question?
  11. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Has anyone ever heard of someone losing a court case where the dealer voided the warranty for missing an oil change by 500 miles?
    I can understand skipping every other oil change and having warranty issues, but not missing the change mark by less than 25%...
