Oil Consumption. 5W-40 ok?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Christian_cool, Sep 26, 2016.
  1. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    Hey all prius friends! My 6 year old still running Toyota Prius 2010 have for a while had excessive oil consumption like last 2 years. Well i went several times to my very cheap dealer and let them put 0W-20 original oil in. After my wallet was half the weight i drove my car as normal, like Mostly country roads. After some 4000 km drive i got a msg on screen telling me oil something i guess preassure was low. Yeah i checked it, and she was empty of fluid damn. i was stupid not to check it regulary like i did other times... So i went to my local supermarket and found they had Shell Helix Ultra on sale 5W-40 and after reading some threads that using this thicker oil would improve oil consumption i gave it a try. Its a 4 L bottle and i only fill 2 liters inside since it adviced not to fill to top and i didnt change oil (only fill)
    I drove 4000 km since that, and i was SURPRISED that the oil level only dropped a little! and i feel its running more smooth meanwhile i also cleaned the egr and intake manifold. Until now i havent experience any problem or signs where the car says "i dont like that, give me another round of beer"
    Have any of you guys same experience, or you advice i should use another type of oil?
    Thx for any help and reply! :) :)
    Chimi1 likes this.
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    main thing is, if it works for YOU, just use it//
    Mendel Leisk and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I am using 5W-30. I have consumption at a quart every 6500 miles. Did some other things to help fuel economy and oil drink, but a thicker oil will help;).
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Why does the 2010 year Prius, seem to burn so much oil??? I keep seeing threads about 2010 cars.
  5. orenji
    orenji Senior Member
    5,884
    3,486
    I believe European car manuals say you can use thicker oil, rather then 0W-20 oil. Have you checked your manual? 0W-20 will give you the best MPG, but for motor protection a 30 or 40 weight oil will be better. See if you can fine a 0W-40 weight oil, as this will give you better protection on cold starts.
    exstudent likes this.
  6. StarCaller
    1,246
    697
  7. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    One reason could be the production run as the sample size is bigger ( more Prii made). Another could be how they are used and maintained. @Rebound in another thread had a good point. When these were being sold, gas prices were high, leading to large fleet purchasing. With some drivers having the opinion "not my car" they can get mistreated. Now they are sold on the used market.
    Or an owner will just neglect to check certain items (like the dipstick), then get the warning light for low oil level, the sump goes dry and the problem is now severe.
    While I have some oil consumption, if I was at a 5k oil change I wouldn't notice. That is another factor. Toyota started this at 10k intervals, so I kept it.
    So many reasons, but easy to keep a small problem from becoming large by simple weekend checks;).
    Coast Cruiser likes this.
  8. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    READ THE Fahrvergnügen Manual!
    Prius owners manual's for non-USA Prius actually shows an ambient temperature chart and a corresponding multigrade oil weight. Below is a page from a UK 2012 Prius Owners Manual.
    It sees you do not understand what the viscosity numbers for oil mean. READ this, you will become enlightened.
    Motor Oil Viscosity Grades Explained in Layman's Terms
    +1
  9. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    Slightly thicker oil is a good way to address more oil use, so long as the oil is still compatible with your climate. As you've mixed 0W-20 and 5W-40 oil, the viscosity of your oil now is probably around a 5W-30 oil, which shouldn't be a problem in Germany (Siberia/Alaska would be another matter...). You'll pay for it with slightly worsened fuel economy (In the 1-2% range), but it's likely worth it with the reduced oil use. You could try a 5W-30 on your next oil change if you're comfortable with your oil usage, and I would think the oil use would be about the same as your current oil. Otherwise 5W-40 shouldn't be a problem either. Per exstudent's post, even a 10W-30 or 10W-40 should be okay down to about -18 C (about the coldest it can get in most places in Germany, if my memory is correct).
  10. Mendel Leisk
    38,739
    Mostly the same as UFO sightings, anything can gain momentum.
  11. Coast Cruiser
    2,267
    2,571
    Well, I hope my 2016 is not going to start burning oil in 4 or 5 years. Did I also see threads on here from 2012 owners? And 2014 owners? Their Prii was using a quart of oil.
    I've never had to add oil to any of the cars I owned in the past. (VW, Nissan, Honda, and my Camry.)
    If my Gen4 starts burning oil someday, you'll find it floating along the coast! :ROFLMAO: Adios Prius!
    Raytheeagle likes this.
  12. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    If it does happen, will it go off the bridge that was your avatar awhile back;)? I guess the mice won't get it floating out to see either:).
    Or you could let us high mileage travelers know and we'll keep her going:D.
    I'll would have to get used to the Star Wars storm trooper white accents. Not my favorite thing about the interior:confused:. But mpg north of 60 would be fantastic!
  13. Coast Cruiser
    2,267
    2,571
    Ray, I have something WORSE than white accents... Harvest Beige cloth interior! :LOL: :eek:
  14. Coast Cruiser
    2,267
    2,571
    ZOOM!!! Right off the end of the pier! :ROFLMAO:
  15. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    All while quietly doing 83 mpg:p!!!
  16. Coast Cruiser
    2,267
    2,571
    I will never see 83 mpg again in my lifetime!
    Something weird happened that day. All the stars and the planets and the moons must of lined up just perfectly… :eek:
  17. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    At least you got a pic of the performance:).
    I was at the bowling alley a couple of weeks ago with my son and I actually bowled a 200( usually it is a stretch to get to 140). When I told the wife she asked for proof:rolleyes:. I forgot to snap a shot of the overhead screen:(.
    This was a Sunday, so maybe the same day of your weird occurrence. Must be a California thing:whistle:.
  18. Christian_cool
    92
    17
    Germany
    Thanks for all your fast reply, i feel comfortable to keep going with this Oil then !
    I have passed 206.000 km - 128.000 Miles with my Prius now and it feels like she want to live forever, ill hope! :D
  19. StarCaller
    1,246
    697
    just broken in/
    now the fun begins/ ;)
  20. Christian_cool
    92
    17
    Germany
    HAHA time to visit the dealer for some coffee more often ;)
