oil consumption fixed(?)
Discussion in 'Gen 3 Prius Main Forum' started by rufuslyon, Jul 17, 2024 at 3:14 PM.
  1. rufuslyon
    rufuslyon Junior Member
    los angeles
    hey guys/girls! I recently replaced the head gasket on my 2010 Prius (250k miles) I found this video explaining that a clogged EGR cooler can be major culprit for the notorious oil consumption. With everything apart, I inspected my egr cooler and found that it was completely clogged. I soaked it in oven cleaner for a couple days and then flushed it out with a pressure washer at my local car wash (wear eye protection). I also switched my motor oil to the new Valvoline restore and protect. Just did my first oil change and noticed that I was only down .5qt over 5k miles instead of my old average of 1-1.5qts every 2-2.5k miles.
    I don’t know if it’s because I cleaned out my EGR valve or the oil cleaning the gunk out from behind the oil control rings as advertised or the combination of both but it seems to be working.
    I’ve also tried the MMO/seafoam piston soak in the past and it didn’t do anything.
    just wanted to share in case this helps any of you
    #1 rufuslyon, Jul 17, 2024 at 3:14 PM
    ForestBeekeeper and JC91006 like this.
  2. Tombukt2
    Tombukt2 Senior Member
    9,098
    1,576
    Durham NC
    Generally with these it turns out to be more of the oil control range I didn't look at your mileage but I imagine it will return but no big deal it's real common
  3. rufuslyon
    los angeles
    yeah, I’m not expecting it to be like factory new. all ice burn some oil. it just brings a little peace of mind knowing that I’m not gonna grenade my motor from oil starvation on a long road trip.
    ForestBeekeeper likes this.
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    703
    274
    Maine
    I am glad to see that this helped. :)
