Oil control valve filter, maintenance interval?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GiIgamesh, Nov 6, 2016.
  1. GiIgamesh
    GiIgamesh New Member
    US
    I had a P0011 code that the ECU faulted on. I checked the control valve and the o-ring looked fine. I didn't test the valve with a battery. I read in a priuschat thread that you should check the filter. I found nothing in the small metal filter but I now want to know after how many miles should it be cleaned? I suspect the fault code was false positive. If the error comes up again I will probably change out the control valve.
  2. Patrick Wong
    18,200
    6,474
    Odometer reading?
    There is no spec for filter cleaning.
    One possibility is that the camshaft drive chain has slipped. The DTC is supposed to be logged if the actual timing is more than 5 degrees from the target value.
    If you have Mini VCI you could issue a software command to turn the oil control valve off and on while the engine is idling, and the engine idle should become rough or the engine should stall when the oil control valve is turned on. That proves the valve is operational.
    valde3 likes this.
  3. b100
    b100 Member
    141
    73
    Netherlands
    Or stretched that was in my case with my P0016
