Oil control valve filter (vvti) on gen3?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by abubin, Jan 4, 2022.
  1. abubin
    abubin Member
    188
    92
    Malaysia
    I saw some video that Toyotas have this OCV/VVTI filter that need to be cleaned once a while. However, seems like Gen2 Prii have this while Gen3 Prii doesn't.
    Anyone know why the did not include this filter in later model? I am assuming Gen 4 does not have such filter also.
  2. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    Don't know but a quick look at parts fiche will tell all. Some engines have catch boxes on side of block . Most don't. .
  3. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Prius is not listed
  4. Tombukt2
    12,214
    2,155
    Durham NC
    Yes this looks like it's some part for the 2AL type of engine that went in the Camrys and whatnot and I think it has a oil separator box on the side of the block and some rubber things and that and various and sundry other things that would not pertain to Prius ZZ or Corolla but oh well
  5. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
  6. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Anyone got a link for where this filter is located and proof that it can get clogged and needs to be periodically inspected?
  7. ChapmanF
    17,347
    For Gen 1 and Gen 2 (that is, the 1NZ engine, also Prius c) the oil control valve filter is easy to access, behind a threaded plug conveniently on the front of the cylinder head (15678A here).
    For Gen 3 and 4 (the 2ZR engine), you have to really, really want to fuss with the filter, enough to take off the valve cover and the #1 camshaft bearing caps. (The part callout is still 15678A below.)
    Mendel Leisk and PriusCamper like this.
  8. PriusCamper
    12,064
    4,896
    Thanks for this... Have you ever seen one that was fouled? Seems like primary engine oil filter would prevent this from ever needing to be serviced?
  9. ChapmanF
    17,347
    I've never laid eyes on one, period, except in the drawings.
    I suppose if I were ever tearing into the head for some reason, I would give it a look-see.
  10. Tombukt2
    12,214
    2,155
    Durham NC
    That will be very soon for me I will have a gen 3 2013 $270,000 mile engine out with its transmission sitting on the floor for disassembly to look at how bad and nasty the mess is
    mjoo likes this.
  11. abubin
    abubin Member
    188
    92
    Malaysia
    Thanks for the information. Looks like the filter does exist just that it is hidden inside the engine. And I would think you seldom need to worry about it clogging as they hide it such a way that it's hard to access to be a periodically serviceable part.
    However, I was asking because I did saw some videos about some very dirty such filter and that it is one of the reason for high gas consumption and other related issues.
    I did pull the OCV filter out of another Toyota Vios (Yaris sedan) which had this filter. That filter was clean and no sign of clogging for a 12 year old car.
  12. ChapmanF
    17,347
    You can have mine for $135,000
  13. Tombukt2
    12,214
    2,155
    Durham NC
    I have a Yaris here too with like 300 some odd thousand on it I have to check it it looks like this thing just screws out of the head.
