Oil dipsticks -- why are some just straight...
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Sep 18, 2017.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,135
    1,560
    Iowa
    And, others, such as the Prius, have a curly end?
    A google search did not find an answer.
    m.wynn likes this.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    :eek:
    :ROFLMAO::ROFLMAO::ROFLMAO:
    RCO likes this.
  3. Tideland Prius
    16,073
    Why do I feel like this is the start of a (bad? good?) joke?
    RCO likes this.
  4. ETC(SS)
    6,494
    Well....
    You see....when two cars really love each other......
    m.wynn and Mark57 like this.
  5. bwilson4web
    15,406
    I'm not sure but perhaps the answer is embedded in this 8 minute video:
    In the old days of straight cylinder, push-rod valves and flat-heat engines, the lower end, the crank shaft end and oil pan were the largest volume of the engine. So it was easy to use a rigid oil dipstick to measure the oil level and then things got complicated.
    The V8 engines pretty well blocked a straight path to the oil pan. Then the quad-valve, dual-overhead cams made the top as large as the crank shaft and oil pan. So flat, flexible oil dip sticks were needed that could take a bend to reach the oil.
    #5 bwilson4web, Sep 19, 2017
    pilotgrrl and RCO like this.
  6. cyberpriusII
    1,135
    1,560
    Iowa
    Ask a simple question....
    I still need to reset the main/required light. Would be nice if all you had to do was "touch it" for it to go away.
    I had a bit of a hassle this time changing the oil. Went the cheap route and bought a five quart jug -- since the price was so low. But, miscounted the "glugs" and overfilled the oil by about 1/4 of an inch.
    Thought about ignoring it, but knew it would bother me....
    so, lucky I have the Fumoto valve installed http://www.fumotousa.com/
    So, it was no big deal to drain the extra oil, but while the oil on the dipstick was pretty near clear and next to impossible to see, the stuff I drained was fairly black and dirty looking. This was after I had "changed the oil and the filter."
    Never again with the five quart jugs.
    Sticking to the quart bottles.
    #6 cyberpriusII, Sep 19, 2017
    jdcollins5 and RCO like this.
  7. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    Just use an intermediate container. Fill a 1 quart container from the 5 quart jug, pore in engine, repeat...
    The total refill amount seems to vary by how patient I am in draining the oil. It takes less when I rush everything, and more when I go off and do something else while it drains. 3.9 quarts is too much in my experience. So I start with 3.5 quarts and watch the dipstick.
  8. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    IMHO you're the master (mistress) of inuendo, whether that's inadvertently or by design.
    cyberpriusII likes this.
  9. cyberpriusII
    1,135
    1,560
    Iowa
    A lady never tells, but if it helps you out, I had two older brothers....it was survival of the .... (I originally mistakenly wrote four brothers -- it actually seemed like four -- I am tired --).
    The good thing about this was that while they had no trouble giving me trouble, if anyone else tried it, it was like I had a US Marine guard squad.
    #9 cyberpriusII, Sep 20, 2017
    RCO likes this.
  10. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    I had two older sisters, not the same thing at all. ;)
    bisco, Mark57 and Raytheeagle like this.
  11. Prius Maximus
    Prius Maximus Senior Member
    930
    775
    Northeastern IL
    I almost always use the 5 quart. For Prius needing 3.5, I pour off 1.5 into 2 old oil cans. Next time I top off the half and fill 1 more. Now I have 3 full qts. After the next change, I have the full 3.5 qts + 1 extra. I don't have to buy any oil the time after that. Pouring off 1.5 qts each oil change is easier than pouring off 3.5 qts each oil change.
    RCO and Trollbait like this.
  12. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    It's because the Prius dipstick really likes being inside its engine. Other dipsticks, not so much...
    #12 mjoo, Sep 21, 2017
    pilotgrrl likes this.
  13. bisco
    48,990
    mine is straight...(n)
    #13 bisco, Sep 21, 2017
  14. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    For once, I'm lost for words. :X3:
    pilotgrrl, bisco and Raytheeagle like this.
  15. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    I have four younger sisters, and we all have many Toyotas among us. However, I'm the only Prius driver.
    mjoo likes this.
  16. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  17. Mark57
    2,945
    2,735
    OK
  18. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    Mating adapters! My virgin eyes!
    Pixel XL ?
    Mark57 likes this.
  19. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Well you see cyberpriusII, when a boy reaches a certain age he goes through changes.... and.... umm..... Here's a book, read it, and if you have any questions, ask your mother!
    pilotgrrl, Mark57, RCO and 1 other person like this.
