Oil does not show on dipstick
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SC Prius, Feb 18, 2011.
  1. SC Prius
    SC Prius Junior Member
    Sumter SC
    I have a 2006 with 154,000 miles on it. I usually have my oil changed at Valvoline, but the last time the tech said there was no oil in my engine. He did drain oil out of it and filled with 3 1/2 quarts of oil. It did not show on the dipstick. This last change I did myself and used 3 1/2 quarts of oil, ran it around the block, waited about 5 minutes checked it and it still does not show on the dipstick. Could I have gotten the wrong dipstick at some point? This one fits and seals good. Any help would be appreciated. I now do not want to run very long not knowing what my level is. Can someone measure their dipstick length? (Insert rude comments now) To compare with what I have.
  2. dinger_greg
    dinger_greg New Member
    86
    Brookfield, WI
    Are you pushing the dip stick down completely? Dipstick length from top to bottom including the ring is 18.5" I will leave out the comments ;)
  3. SC Prius
    Sumter SC
    MIne is 18.5" end to end, when checking the length, it is on the twisted end now. I would think it would be higher from reading other posts.
  4. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I doubt that your dip stick has been swapped. What is the Gen. II oil capacity? Simple fix add oil to it reads full on your dip stick. I also doubt that your engine was totally devoid of oil you would not have gotten very far.
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Are you using 0-20 or 5-20. Some oils can be hard to see until you get some hours on the ICE. Hal
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    How much oil drained out ?
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I think what is confusing is your contention that a technician said your engine was "without oil" but then simultaneously stating he drained it...Well if it had no oil what did he drain out?
    Similarly...unless your oil is almost immediately being drained out...as you pour it in..which I'd guess you'd notice...if you put 3 1/2 quarts in? Then you have oil in your vehicle.
    First step...measure your dipstick...
    If you bought your vehicle used...it is possible a shady or uneducated dealer simply threw the wrong dipstick for your vehicle...
    If it isn't reading anything? Huh...it's almost got to be too short...
    I would also establish that you either have the right dipstick or not, before I would recommend simply adding more and more oil....overfilling can be a real problem.
    Are you anywhere near a Toyota Dealership...I'm guessing this controversy whether proper dipstick, or Titanic Sinking Oil leak, or strange rip in the fabric of time and space could be settled in about a Nano-Second by a technician familiar with a Prius.
  8. SC Prius
    Sumter SC
    5-30 and it is difficult to see.
  9. SC Prius
    Sumter SC
    Thanks for the replies, I'm leaning towards bad service at a minimum wage lube change center, or mis calibrated dispenser. The drain bolt had a washer on it, which was replaced this last time by me, and 3 1/2 quarts went in. No indications of a leak anywhere under the car. I'll recheck the reading i the morning and use a paper towel laid directly on it to see what the level is, rather than trying to read new oil.
  10. SC Prius
    Sumter SC
    Close to 3 qts, but I did add to get it on the dipstick. I assume witht he position of the oil filter being down that it keeps a good quantity of oil above it. Other cars did not drain as much oil out of the filter when removed as this car does.
  11. Patrick Wong
    18,200
    6,479
    Fresh engine oil will appear as a clear film on the dipstick. Are you holding the dipstick so that the flat surface will reflect available light into your eyes? If you are doing so then you should see where the oil film is present.
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    +1 on the optical trick. Also I found it much easier to see when the engine is cold and the oil film is thicker due to higher viscosity at lower temperatures. Last time when I changed oil I filled 3 + 10/32 qt. (including the amount filled in the oil filter) and the level is about 13 mm below the "FULL" dot on the dipstick.
  13. uart
    uart Senior Member
    4,215
    1,201
    Australia
    I've usually got to put about 2000 to 3000 km on my oil before it just starts to get a tiny bit of color to it and then it's not too hard to see. After I've just changed the oil it's really hard to see on the dipstick.
  14. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Also bear in mind that you should check the oil on a cool motor that hasn't been running for at least an hour. When the engine is shut off, it takes time for the oil to drain back down into the pan so you can check the level accurately.
    If you shut your car off and then immediately check the level...it'll be low...even when its not.
  15. Mendel Leisk
    38,875
    That sounds sensible, but I've found little difference checking immediately vs waiting a while. In other words, the oil level in the pan stabilizes very quickly after shutdown.
  16. uart
    uart Senior Member
    4,215
    1,201
    Australia
    If the oil is warm it stabilizes pretty quickly. I find that after about 5 minutes the measurements will usually be within about 1/16" of it's final value. I usually wait about 5 to 10 minutes before checking.
  17. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    First off, You should have put in 4.1 qts. not 3 1/2, if you changed the filter. Look in your owners manual. But... even @ 3 1/2 it should have shown on the stick
  18. richard schumacher
    7,663
    1,040
    United States
    The owner's manual is very misleading about this. The *dry* capacity, new in the factory, is 4.1 quarts. Half a quart or more always remains in the engine, so 4.1 is too much to add when changing the filter and oil. For example, I add exactly three quarts to mine and the level ends halfway between the ADD and FULL marks, which is perfect.
    But yeah: either the OP is just not seeing the oil on the dipstick, or something is gruesomely wrong.
  19. SageBrush
    11,627
    2,531
    Southwest Colorado
    :eek::eek:
    Bad advice
    Silver Pine Mica and Rae Vynn like this.
