Oil door Fastener part numbers
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rebomar, Oct 22, 2013.
  1. rebomar
    rebomar New Member
    2010 Prius under engine splash plate. The oil access portion has 3 push-in plastic fasteners. The side ones are smaller and all black. The back one is larger in diameter and is black on the outside with a gray center pin. Can anyone provide a Toyota part number for the larger fastener. The local dealer says they are all the same size.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I picked a few different sizes @ NAPA. Nice thing about those, it there were much better built and designed to be reused.
  3. Mike500
    Mike500 Senior Member
    2,593
    764
    The smaller one fit a 7mm hole, and the larger one fit a 9mm hole.
    For permanence, I replaced them with a 5mm rivet nut for the smaller one and a 6mm rivet nut for the larger one.
    That way, I can use a 5mm and 6mm stainless Philips head screw for each. I no longer fiddle with those weak "easy to come off while driving" plastic push rivets.
    Make Your Own RivNut Tool | Carolina Rover Owners Club
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    4 years now and never had one come off while driving.
  5. Mike500
    2,593
    764
    Yeah, heavy snow, gravel and road debris in North Carolina, but not likely in Wilmington.
    jdcollins5 likes this.
  6. Mendel Leisk
    38,736
    I think they're item 5, p/n: 90467-09227 (Thicker Metal & Plastic Clips), per the attachment.
  7. gliderman
    gliderman Active Member
    751
    223
    The part number you are looking for is 90467-07166
  8. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I still have the HDD neodymium magnet holding the oil change door fully secure.
    I'm at 42K.
    Just one more option.
    my2cents.
  9. jdcollins5
    5,131
    1,338
    Wilmington, NC
    The Toyota part numbers that I have from purchasing in 2011 for the engine undercover, which includes the oil door, are:
    90467-07215 - Clip - for the smaller one that is solid black
    90467-09227 - Clip - for the larger one with the gray center pin
    90119-A0098 - Bolt, with washer - 10mm bolt
  10. gliderman
    751
    223
    I bought 100 7mm clips cheap on ebay and some 9mm clips. I just bust them off if they are hard to open and replace with new ones. Makes it a lot faster and easier.
  11. solrunner
    solrunner Member
    114
    37
    Reston, VA
    I've seen other people on here just use plastic zip ties. That's my plan when I get around to it.
  12. Mendel Leisk
    38,736
    I can't see plastic zip ties working as a replacement for the push in fasteners. Will not work, for starters, and defeats the purpose of removable fastener.
    If you remove the fasteners carefully, wash them, sluice the grit out, they will last a long time. I've done 10 oil changes now where I've removed the engine underpanel completely, have yet break one. The parts numbers are posted up the page (post #9, and n the pdf in my post #6), if you do need replacement.
    Google "paint can opener tool image" to see a flat-bladed tool with right angle tip, handy for lifting the fastener heads.
    @Danny It's now impossible to post even a small image.
  13. JBarleycorn
    JBarleycorn Junior Member
    Can you tell me how to remove a broken fastener from its hole? I did my first DIY oil change on my car yesterday, and I see that the dealer (at the 10k or 20k mile o/c) had broken the head off the main fastener of the oil access panel. I tried to pull the fragments out with a pliers but that didn't work. Is there a way to get the remains of the broken fastener out of the hole, or push it in until it disappears, or whatever?
    [I tried to post this question yesterday but it didn't show up. Apologies if it now shows up twice.]
  14. Mendel Leisk
    38,736
    I've been dealing with these for a few decades now. When the cap breaks the internal jaws and metal bits typically break apart, become easy to extract. If that's not the case and it's hard to grip, yeah: I'd just push it in.
    If you get into regular DIY changes, rinse out the fasteners whenever they're removed, replace any broken ones with OEM, use the right tools, you'll have no problems.
    I'll try posting my favourite push-in fastener removal tool pic again:
    Nope, not happening. @Danny PLEASE fix this. (Win7, lastest IE)
    (No work on iPhone too :()
    #14 Mendel Leisk, Feb 14, 2016
  15. JBarleycorn
    Okay thanks - I will try just pushing it in. I'll get back to you the next time I get the car up on the ramps, probably about 10000 miles from now. :)
    And needless to say, this is why I'd like to do my own oil changes !
  16. gliderman
    751
    223
    The broken pieces are easily pushed through.
    If you have gotten the impression that I break them all off, I dont. The OEM are no different from the aftermarket. Sometimes they are just difficult to remove or are brittle. I have several tools made specifically for removing these push fasteners, and the fasteners still break. If you dont want to use the same push fastener like the OEM, there are screw fasteners that work great too. Instead of pushing the pin in to expand the fastener, you screw in a plastic screw that expands the fastener and is easily removed and reused. These arent the ones I bought but they are very similar. I havent used them yet because I am using up all the push fasteners first:
    Car Auto Plastic Fasteners Push Clips 60pcs for 7mm Hole Dia | eBay
    JBarleycorn and Mendel Leisk like this.
  17. priusplus_fr
    priusplus_fr Junior Member
    29
    22
    France
    2012 Prius+ MPV
    For those who have bought compatible/generic fasteners, do you care about the height of the fastener? or that is not so important.
    Does the hole size only matter?
    Thanks for your feedback.
  18. Mendel Leisk
    38,736
    I think both the diameter and length matter. Assuming you still have some of the Toyota fasteners: measure them carefully beforehand, try to find fasteners of the same style and dimensions. If they're a good fit they'll be snug, not hard to push in, and the center caps will click positively and easily when you push them down. When removing fasteners that have been in for a while, rinse them in hot/soapy water, to get trapped grit out. That's what can jam the mechanism, cause them to break.
    priusplus_fr likes this.
  19. gliderman
    751
    223
