Oil drain pan bolt thread size
Discussion in 'Prime Main Forum (2017-2022)' started by YMS_1975, Feb 18, 2020.
  1. YMS_1975
    YMS_1975 Junior Member
    Ontario, Canada
    2020 Prius Prime
    I was wondering if anybody could tell me the bolt thread size, for the oil drain pan, on a 2020 Toyota Prius Prime.
    I want to buy the EZ-OIL Drain Valve for my car.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Doesn't the manufacturer have a reference for Toyota Prius? It is likely it is the same for the Gen 4 Hatchback, 2016+. Also very likely the same for the Gen 3, 2010+ since they all use the same ICE beginning in 2010
  3. Prodigyplace
    12,678
    11,830
    Central Virginia
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,498
    Taylors, SC
    M12x1.25 for the drain plug.
    The bolts that hold the oil pan to the lower engine housing are M6x1.0x10mm long.
    Mendel Leisk and Prodigyplace like this.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    EZ103 valve is the one you need.
  6. Schrauger
    Schrauger Junior Member
    27
    That's the same one I had on my 2007 Gen 2 prius. Good to know that I can reuse it when I'm done with the first couple free oil changes on my Prime.
    Salamander_King likes this.
  7. Mendel Leisk
    41,901
    There's a couple of threads going, regarding these oil drain taps. I've been sitting on my hands, but gotta say:
    The oil pan drain bolt is pretty much the lowest thing, and kind of angled down. I don't think I'd want some sort of tap there, pointing down and able to be levered. It could be snapped right off (catastrophic), or just bent enough the oil pan needs to be replaced?
  8. Salamander_King
    11,024
    8,970
    New England
    I have never re-used the oil drain valve on my cars. Can you replace a Viton-O-ring on EZ drain valve with a new one? Or it doesn't need to be replaced?
    Fumoto valves use fiber gasket washer, and they sell replacement gasket cheap. 12mm Gasket for F-103, F-107, F-109 Series Valves | FUMOTO
  9. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    "replace a Viton-O-ring"
    Viton is a synthetic rubber that is resistant to moderately high heat and oil. Never replace with a common nitrile (neoprene) o-ring that has little heat tolerance and not the best for oil. I've used viton successfully on 250°F fuel oil. Worked great. (This was heated black oil for diesel engines.)
  10. Salamander_King
    11,024
    8,970
    New England
    Thanks for the info. Not that I plan to replace viton-O-ring, but do you know if EZ valve sells replacement viton-O-ring like Fumoto? If they sell, it is not easily found on their web site.
  11. Georgina Rudkus
    3,511
    2,498
    Taylors, SC
    Viton is a DuPont trademark for fluroelastomer. It received a lot of notoriety during the Challenger space shuttle disaster.
    They can be purchased in specific sizes on Amazon, W.W. Grainger or as an assortment at Harbor Freight.
    180 Piece Viton O-Ring Kit
    Prodigyplace and Salamander_King like this.
