oil drain plug nut size
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by abubin, Feb 1, 2021.
  1. abubin
    abubin Member
    193
    92
    Malaysia
    Can someone please confirm what is the correct size for Prius oil sump nut size?
    There seems to be 2 sizes given, M12x1.25 and M12x1.5.
    I am assuming the 1.25 and 1.5 is the thread size? Which is correct size? Cause I just realize my other car thread size was wrong and it stripped the nut. Luckily the nut I got is made of aluminum. I wanted to make sure for Prius I didn't screw up the size. No puns intended.
    Rifaqat Shah likes this.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,497
    Taylors, SC
    M12x1.25
    abubin likes this.
  3. Mendel Leisk
    41,894
    If you have dealership nearby, they would have the genuine one. It’s 14 mm socket size fwiw.
    it’s a bolt btw.
    Majafamily likes this.
  4. abubin
    abubin Member
    193
    92
    Malaysia
    oh yeah it's bolt. Damn, why do people here call it nut. Old skool foreman terminology.
  5. ETC(SS)
    7,350
    The nut usually goes INSIDE the car between the steering wheel and the seat......
    jerrymildred and Majafamily like this.
  6. ChapmanF
    18,536
    Our biggest oil drain plug nut around here might be cyberpriusii.
    jerrymildred likes this.
  7. hill
    8,916
    Never hurts to spend a few dollars to have a thread gauge
  8. Mendel Leisk
    41,894
    And then Toyota calls it a "plug":
    PLUG
    Genuine Toyota, Genuine Daihatsu, Genuine Hino (9034112012):
    Genuine Toyota 90341-12012 (9034112012) PLUG - Amayama
    If you order through above, shipping for the single item would be onerous. But add something like wiper blades, air filters, and shipping doesn't increase much, makes it more worthwhile. Anyway, there's the part number and description.
  9. ChapmanF
    18,536
    I generally get my 0w20 from the dealer here anyway; no better prices in town, last time I checked.
    Once I'm already there, if I had to spend even $4 or the full undiscounted $5.55 because I needed a plug one time, it would hardly be worth my time to run around looking for cheaper, or fuss with an overseas order.
  10. Mendel Leisk
    41,894
    Yeah I get everything at dealership too. @abubin ’s location might not have dealerships nearby, not sure. I’ve suggested he get the drain bolt from dealership (if practical) and in my last post supplied him description, part number, and a mail order source, if needed.
    That's ok?
    #10 Mendel Leisk, Feb 2, 2021
  11. ChapmanF
    18,536
    Never mind me, I'm just a big oil drain plug nut.
    jerrymildred and Mendel Leisk like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Nuts for the nuts?
    Yeah, it's technically a plug.
    If it held something onto something else it would be a screw.
    Unless there was a nut on the other end. Then it would be a bolt.
    Easy to remember if you've ever used a nut for fishing. Almost every time I cast that nut out into the pond a fish will make a bolt for it. :ROFLMAO:
    #12 jerrymildred, Feb 2, 2021
