Oil drain valve -- who uses one? Discount for the enlightened
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Jun 17, 2022.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,573
    Iowa
    This is one of the better deals I have seen for Fumoto -- 15 percent off -- not that it is that much of a savings, since the valves are relatively inexpensive....
    Happy Fathers Day from Fumoto!
    Starting today take 15% off your order with code: FATHERSYAY
    This offer ends at midnight on Father's Day 2022
    https://www.fumotousa.com
    My dad had them on all the cars as far back as I can remember and never had an issue. Indeed, he put them on my first two cars. I love them. It makes an oil change possible without tools -- depending on who put the filter on and how tight.
    I don't need any, but for those who might...Oh, I don't know what is meant by midnight. Since FumotoUSA is in California....I might assume....
    kris
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Thanks for the code, but with shipping, still more than Amazon.
  3. PriusCamper
    PriusCamper Senior Member
    11,071
    4,507
    Pacific Northwest, USA
    If they made one for oil filter replacing I'd be interested. But not for an easy to remove bolt...
  4. Trollbait
    11,518
    Which usually results in getting oil on yourself, or on the ground. You can attach a hose to these valves to avoid that.
  5. PriusCamper
    11,071
    4,507
    Air ratchet on an extension with a socket that doesn't let go of the bolt is way easier and cleaner than not remembering where your dirty oily hose has wandered off to...
  6. cyberpriusII
    1,136
    1,573
    Iowa
    Though I do like to save, for various reasons I avoid Amazon...search reasons to avoid....The dirty oil drain hose stays with the dirty "draintainer."
  7. Trollbait
    11,518
    Great if you have an air tool set up.
  8. ETC(SS)
    6,545
    DONE.
    Didn't really find anything....BUT....that's probably a different topic, for a different thread, perhaps in a different forum.
    You're not childish enough (or, you're too smart) to go into FHOP_P.....so we'll just have to leave that lie.
    I maintain four vehicles, and I've never really been tempted (enlightened enough?) to use one.
    Perhaps when I'm too old to ride a bike....;)
  9. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I have Fumotos on my cars and I LOVE them.
    When I change oil, I attach a hose to the valve, and it drains straight into a milk jug. I fill one jug, close the valve, then drain into the second. NO DRAIN PAN CLEAN UP.
    Mendel Leisk and Trollbait like this.
  10. Mendel Leisk
    38,669
    I drain the oil directly into the container I take down the trail, pour at Mr. Lube's recycled oil tank, take it home. Never need to clean it out; no oil contam'd containers left at the recyclers.
    #10 Mendel Leisk, Jun 27, 2022
  11. John321
    John321 Senior Member
    1,200
    1,200
    Kentucky
    Here is another type oil drain valve I will probably buy next time I change oil.
    ValvoMax Oil Drain System
    The Future of Oil Changes - New Invention - YouTube
    Our little PHEV sits close enough to the ground that it is impossible to get a large ratchet bar on the drain plug without jacking up the vehicle and taking off the wheel. This would eliminate that necessity and probably make the whole job quicker, cleaner and safer.
    The Company is Veteran owned and the system is made in America.
    #11 John321, Jun 27, 2022
  12. xliderider
    7,869
    3,116
    Honolulu, HI
    There are several similar systems/valves out there:
    NO-SPILL OIL DRAIN KIT | Kit Contains: Dust Cap, Oil Plug, & 10" Hose | Compatible with Various Models, Makes, and Manufactures | Select Your Application https://a.co/0nrXYI8
