Oil Filter Won't Unscrew
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tak, Aug 30, 2010.
  1. Tak
    Tak New Member
    redwood city, ca
    Unscrewed counterclockwise. won't budge. Tore filter - removed core - Looks like the filter is attached to a rod what was attached to the engine with a large Allen Head wrench. Can I use an Allen Head wrench or is there a better way to detach the filter.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Never seen this,
    Did someone tighten the filter with a tool? They should only be fitted hand tight.
  3. Patrick Wong
    18,200
    6,492
    Yes, you could use an Allen key socket to remove the threaded oil filter union. Note the tightening torque of that part is 22 ft.-lb, when you reassemble it.
    After you remove the oil filter union, I hope you will be able to separate the filter remnants from the union.
  4. derkraut
    derkraut Member
    299
    28
    SAN
    Wow! someone really screwed that sucker on too tight! Like Pat says---22ftlbs max should be applied.
  5. Patrick Wong
    18,200
    6,492
    Tightening torque spec of the oil filter itself is 13 ft.-lb. However I just rotate the filter 1/2 turn by hand after the gasket contacts the machined surface.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I've had to deal with this a couple of times in my life. It happens when some monkey at a garage puts an oil filter on super tight and dry.
    I've been forced to carefully chisle off the remains of the oil filter mounting base
    That really is the only way to get it off now. Be careful not to gouge the mating surface, or you may have a leak
