Oil Leak Part ID
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FBZTO, Nov 17, 2024.
  1. FBZTO
    FBZTO New Member
    Toronto
    Hi guys long time lurker.
    Have a gen 2 that has a slow oil leak. I believe it's some kind of connector. I cleaned the bottom up and this part pool oil. The metal around the part seems clean. Any idea what this part is. It's located on the passenger side just below crank pulley. Could this be the leak source? It may be higher up but looks pretty clean up there.
    Apologies for the terrible photography.
  2. FBZTO
    FBZTO New Member
    Toronto
    I actually found the part here:
    crank position sensor it looks like. Doesn't seem to be a common leak per the google. I'll do a little more watchful waiting.
  3. Tombukt2
    Tombukt2 Senior Member
    12,009
    2,123
    Durham NC
    Maybe this is a bolt alongside a flange type mounting arrangement or does it screw right into the timing cover of the block either way it probably has a gasket or an o-ring seal maybe you just need to withdraw the sensor full off the o-ring take it to the parts store and match it up with an o-ring lube it up put it on the sensor You should know immediately when you push it back into the cover that the seal is working properly you'll kind of feel it whereas now when you take it out if it's leaking when you pull the sensor out it just pops right out feels like you're doing nothing but when you put it back in with the new o-ring you'll need to have it lubed up and wiggle it side to side so it goes in the whole nicely and scrapes the oil and whatnot down the bore as it installs. But usually oil leaks are coming from further up generally but this is an access point to oil behind the sensor so and it looks like it's got a lot of build up there I'd have to clean all that off and then run the motor and have a good look but as old as these cars are and it's about time for o-rings and things to start wear out just in the time frame of the car's life let alone the mileage and possible poor oil changes You never know.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    The sensor has an O-ring to seal it to the timing cover. That could be seeping.
    Very rarely the sensor itself can seep. Unplug the connector and check for oil inside it.
  5. FBZTO
    FBZTO New Member
    Toronto
    Thanks for the replies guys. I'll pull the connector and take a look and provide more pics to add another data point to this great site.
    Pulling the connector ould also help in determining if it's higher up. The sensor itself looks relatively easy to remove/access.
  6. FBZTO
    FBZTO New Member
    Toronto
    It's not the crank sensor. I was having trouble tracking the leak down. Got some UV dye and I think it's just the oil pan gasket. Got a new one on order. Hopefully that fixes the issue.
  7. saneesh8
    saneesh8 Member
    133
    27
    Allen, TX
    at least it is easy on the Prius. Changing the oil pan gasket.. Had to do it on my 2000 bmw z3. So much work :( Had to hung the engine with support bar, remove the sub frame and all. All for $25 gasket..
    FBZTO likes this.
  8. FBZTO
    FBZTO New Member
    Toronto
    Just finished the job. Really easy. Went with a felpro gasket instead of rtv. Looks pretty good in there for 280 km.
  9. saneesh8
    saneesh8 Member
    133
    27
    Allen, TX
    Pick up looks clean. Why you didn't use the OEM gasket?
  10. FBZTO
    FBZTO New Member
    Toronto
    Mainly because I just ordered from rockauto didn't realize OEM was just rtv'd on. Hope this lasts as long as OEM
  11. saneesh8
    saneesh8 Member
    133
    27
    Allen, TX
    OEM is just RTV? no gasket?
  12. FBZTO
    FBZTO New Member
    Toronto
    Yes that's right just RTV.
    saneesh8 likes this.
