Oil level 3/8" above top dimple on dipstick
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cycledrum, Feb 27, 2010.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Got the 3rd service (1.5 years old) on the 2009 today. I specifically asked the advisor to note on tech sheet - do not fill oil above top dimple.
    Didn't work. It's 3/8" above top dimple. I was not going to have them drain the oil out, do it a 2nd time. Been there done that last 2 service times. It was really busy with all the recall cars in.
    I have quick oil changes on many other cars and IIRC, they usually come back with oil above top dimple.
    The service director at Piercey Toyota assured me there would be no problem with oil level slightly above the top dimple. If there is a problem later on, the car is under powertrain warranty for 4.5 more years anyway.
    51,155
    the only guy who ever poured the last quart slowly, checking several times as he went until it was at the full line was a private mercedes specialist i used to take my 300sd to. everyone else, above the line. i doubt it is that critical, but not positive.:cool:
  3. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    They always overfill mine - and I've tried 3 different local dealers. I now just drive home and use a tube to siphon some oil out via the dipstick tube. I've got quite a collection of very lightly used oil - actually I use it to oil my chainsaw chain.
    51,155
    is that a special tube? exactly how do you do it? i would like to also, and, i have a chainsaw!:rockon:
  5. enerjazz
    256
    144
    Fairview, TX
    I have a 3' piece of small diameter plastic tubing that just fits down the dip tube. I have a 6' length of larger diameter plastic tubing that I wedge the small one in (using a little tape for a tight seal). When the oil is warm I can easily suck on the end of the large tube and draw the oil up into the tube. When it's almost full (near my mouth), I pull out the tube and drop it into a container (an old antifreeze bottle) and drain it.
    It takes two tubes full to get me from overfill to just under the full line. It's not pretty, but it works.
  6. dogfriend
    7,512
    1,189
    Carmichael, CA
    You can also use a small vacuum pump, like a Mityvac or similar. That is how I did it when the dealer overfilled mine. Another possibility is to remove the oil filter, and drain out the oil in the filter, then reinstall.
    I don't take my car in for oil changes anymore, I just do it myself.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Why do you go back to the same place if the mess it up everytime?
    And I assume your using the dealer oil which is usually vat oil.
    May I recommend Mobil One which enables you to go 10,000+ miles between changes. Then when you do need an oil change take 1/2 a quart out of the bottle and present 3.5 quarts to the oil change crew. With filter that will hit the dimple everytime. No way they can mess that up. Lots of people on Chat do this.
    Much easier than the syphon.And then you have 1/2 quart of virgin Mobil One not slightly used oil only good for a chainsaw.
  8. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I've got another year and a half of pre-paid maintenance coupons. Don't feel like cashing in on that. I could try Fremont Toyota. Sunnyvale Toyota is farther, but they are #1 rated.
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    ** Correction, level was closer to 10mm high, not 6mm **
    The oil level is 10mm above top dimple, measured at operating temp, > 5 minutes after shutting hybrid system down.
    Distance from bottom to top dimple is 43mm. 1.6qt required to go from low to full mark.
    Excess oil = (10mm x 1.6 qt.) / 43mm = .37 qt.
    Invoice says 3.85 qt 5W30 added, so 3.5 qt would put it right under top dimple as confirmed by edthefox.
  10. dogfriend
    7,512
    1,189
    Carmichael, CA
    I have measured it a couple of times. 3.7 qt puts it right at top mark, 3.5 qts is good and leaves it just below top mark.
  11. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I went back to Piercey to get the oil level corrected and I'm glad I did ....
    They brought out a senior technician. We both looked at the oil level, 6mm too high. He agreed it should not be that way.
    The technician, Mike Duong, explained that my car went through the express lube lane. They are under time constraints to finish cars. Also, the oil filters and bolt gaskets are close by, so they put the bolt in without last amounts of oil draining out.
    He offered to ask for him or another Sr. technician next time. Said 3.75 quarts is the amount he uses for a Gen2 oil/filter change.
    Mike explained that in the 1st generation Prius, oil overfilled for a long period of time can get back into the PCV system, IIRC, and into the combustion chamber thereby reducing fuel efficiency. Anyrate, habitually overfilling the oil is not good.
    Some advisors think a little over the top dimple won't hurt anything. I'd rather keep it just under or right at the top dimple.
  12. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    ... and the ironic part is the oil is still 1/4" above the dimple.
    Trouble is, they bring the car out and then want to check it right away. I know the manual says wait at least 5 minutes after shutting off.
    I could do better at home, but the Prius is awfully low to the ground and I'm not buying ramps. And I've got 1 1/2 yrs. of coupons left.
    I'm going to refigure the number of how much to put in with oil/filter change.
  13. Patrick Wong
    18,200
    6,493
    3.5 US quarts is a good amount to use.
  14. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I agree ...
    3.85 qt. - ((10mm * 1.6 qt.) / 43mm) ~ 3.5 US qt. with oil / filter change
    original fill - ((overfill * low to high amount) / low to high distance) = correct fill
  15. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Heck when I did my own fill I think I used 3.5 quarts, which put it right at the full mark. Then I drained just a touch to get it under just to be sure. Then at 5K miles I wanted to have it tested so I drained a sample cup worth for Blackstone. Still no need to add any oil, it's still within .25" of full. Testing showed me I can get to 10K miles on this oil no problem too.
    - D
  16. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Is that tiny overfill really worth all the gymnastics that people have described for removing a couple of ounces of oil? Shouldn't you be more concerned about the possibility of introducing, shall we say, contaminants to the crankcase than an extra 3/8" on the dipstick.
  17. richard schumacher
    7,664
    1,043
    United States
    Buying 3 quarts exactly and handing them to the tech is even better because it's so easy. No screwing around with half-filled bottles, oil syphons, or any such nonsense.
  18. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    3.5 US qts. is the amount to fill, yet the manual states 3.9 qts. I'd rather be safe than have 0.4 extra qt of oil splashing around the crankcase. Mine was over 3/8" above the full line, the top dimple. To me, full means full.
    Piercey drained the oil out and refilled, no siphoning.
    I'll press them hard to only put in 3.5 qts in August.
  19. richard schumacher
    7,664
    1,043
    United States
    The manual is misleading because it refers to the *dry* capacity of the system. The problem is, at an oil change the system isn't dry: there's easily a half-quart remaining in the sump and coating all of the inner walls. Next time try using 3 quarts and see where the level is on the stick. It's a lot easier than yelling at the techs to put in exactly 3.5 quarts and making them redo the job when it comes out overfilled.
    Realize that "full" does not mean "perfect": it means "don't put in any more". Similarly, the bottom dimple does not mean "empty", it means "just barely enough". This may be a cultural thing. The Japanese engineers designed an operating *range*, whereas some Americans think that more is always better. Uh-uh. Nope.
  20. Patrick Wong
    18,200
    6,493
    Beyond the issue of oil accumulating in the intake manifold, it seems that mpg may improve when the oil level is somewhat below the full dipstick dimple.
