"Oil Maintenance Required" Notification After Only 5K Miles??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ZBrink, Mar 20, 2014.
  1. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    Hello,
    I have a 2010 Prius that I bought used this past Fall (2013). I have only had the oil changed once and it was at the local Toyota dealer. The service adviser told me the interval was 10k miles however, the "Oil Maintenance Required" notification is flashing on my dash at only 5k miles since the last change.
    Is this a standard preset notification that trips automatically at 5k miles or does the computer measure the quality of the oil and it is telling me that the oil is shot and I need to change it now?!?
    Thanks,
    Zack
    49,442
    standard, unfortunately. the manual has reset instructions.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I see 'Maint Reqd' in my Gen 2 and v, are you sure it mentions oil?
    There is a Maintenance required every 5,000 miles, tire rotation.
  4. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    JimboPalmer: It clearly says "Oil Maintenance Required" on the info screen.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    You have the first screen on here that says Oil Maintenance Required. Where are you located?
    My 2010 only says Maintenance Requied.
  6. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Isn't that user configurable on the Maintenance section of the setup screen? It's a separate reminder that can be set for oil change, tire rotation, filter replacement etc. I can't remember what all was on that screen.
  7. jdcollins5
    5,131
    1,338
    Wilmington, NC
    You are right. I forgot about the Maintenance Menu in Setup. It has about a dozen different items you can configure either on date or mileage.
  8. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Toyota's original oil change interval was 5000 miles. This was changed to 10000 miles in 2009 but they didn't change the reminder. If you have a nav unit there is a Maintenance Mode that can be used to set reminders and adjust any number of things.
    If I set anything in Maintenance Mode I'm not sure I'd remember to clear it when selling the car. I'd remember to clear the nav data because that's in my face.
  9. jharwd
    jharwd Junior Member
    You still have to bring in the prius for other inspection but not an oil change. Oil change is 10,000 mi or 1 year.What
    ever comes first if they are using the 0-20 synthetic oil.
  10. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    my 2010 Prius Two says oil maintenance required at the 5000 mile mark. I do take the car in for the tires to be rotated and for a check of fluid levels. Probably most people here can do the latter themselves.
  11. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    That's the dealer profit notification.
    ZBrink, jdk2 and xliderider like this.
