Oil maintenance reset (other method)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sasan, Aug 6, 2019.
  1. Sasan
    Sasan New Member
    Huntington Beach
    Hi
    I have prius 2010 and recently two button on the wheel stop working, TRIP & DISP, i cannot change the TRIP and reseting oil maintenance message, do you guys know another way to reset oil maintenance? i mean another way with OBD and command?
    I went to mechanic shop but they couldn't reset it.
    so if anyone now the another method, please post it.
    Thank you
    ::: Please do not post this method, mine is not going to TRIP A because the key is not working :::
    • Turn the ignition ON without starting the engine
    • Press the TRIP button on the steering wheel until you see “TRIP A” on the display
    • Next, turn the ignition “OFF”
    • Press the START button without touching the break and while holding the km/h MPH button.
    • Keep holding the km/h MPH button while the reset is in progress and until you are told that the reset is complete.
    49,479
    welcome!
    idk, but i wonder if you can reset it with tech stream?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Any plans to get the clock spring replaced or buttons fixed?
    You could try pulling the 12 volt lead and it should reset the message.
    Good luck and keep us posted (y).
    CR94 likes this.
  4. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Thank you for your info, but I don't have this button km/h MPH... I have the european version, and the button looks like this...
    I tried the sequence with this buttn, but no luck so far...
  5. bisco
    49,479
    did you follow the o/m instructions for your vehicle?
  6. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Well, my car did come without an owner manual...
    All the manual I read, speak about that button I don't have.
    Nima EB and bisco like this.
  7. bisco
    49,479
    can you access the toyota owners website?
  8. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Yes, I downloaded a manual for my car, but the same, "only for USA version".
    I understand that reseting maintenance data is available only for USA cars...
  9. bisco
    49,479
    here, resetting removes the 'maintenance required' message from the combo screen. do you have a message?
  10. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    You should try to download the user manual from the European site. In Europe we have the maintenance reminder set up in the head unit, you shoukd be able to reset there.
    What is the number of year head unit - right bottim corner, not on the screen?
  11. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    [​IMG][/url][/IMG]
    No, I don't have this message on the screen, but, since I changed oil, I think that a reset will be appropriate...
    Attila, thank you for your message, you are right, I took the manual from US website, I try now to get it from european website...
    This is my head unit number.
    upload
  12. bisco
    49,479
    if you are not getting a maintenance reminder message, what is it you are trying to reset?
  13. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    The reason is I changed oil these days...
    And of course I can wait to reach 12-15000 km (I keep a very accurate track of km) but I like to do it as manufacturer thought...
  14. Attila Fekete
    164
    59
    Budapest, Hungary
    So you have the 59014 head unit.
    If the head unit is what was originally installed, then you can get the manual from Toyota Europe page by entering your VIN.
    Update: And I’m quite sure it doesn’t keep service intervall.
  15. bisco
    49,479
    I understand, but I’m still wondering what it is you’re resetting if you don’t get a message or light or some other indicators
  16. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Because I want to start from zero, as I changed oil now...
    Before me, I don't know when the oil was changed, or when the reset was done...
    PS
    Entering my VIN on that Europe website it gives me only Navigation manual... not owner manual...
    photo url
  17. Attila Fekete
    164
    59
    Budapest, Hungary
    Download that one, if there is a way to enter reminder for the oil change, it will be documented in it.
    But I’m quite sure there is no such option.
    (I have the newer JBL model with 6” display - like yours - but I have no such option. Even the 7” B9038 has only reminder - if you set it.)
  18. bisco
    49,479
    I could be wrong, but I think you’re misunderstanding how the reminder system works, at least in the us
  19. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    In order to clarify this, I think that the reminder will signal when the 10000-15000 km are expired...
    So, if I reset today, after 10000-15000 km the system will notify me by lightening a SYST REQD or whatever else led in DASH...
    Am I wrong?
  20. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    I downloaded but it is not my Navi...
    I will search more...
