Oil or exhaust smell in cabin
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Indysue, Jun 3, 2020.
  1. Indysue
    Indysue Junior Member
    San Diego
    My cab has an oil or exhaust smell, it is much worse when I have the AC on, any clue how I can fix it?
  2. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    Check that your spark plugs are snugged up to the correct torque. If they are ok, can you find any leaks in the manifold or exhaust?
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    VERY DANGEROUS TO YOUR HEALTH.
    I have seen this complaint a few times with no poster resolution post. I do know the donut connection at the end of the exhaust manifold where it connects to the main exhaust runs gets loose over time. Once when i was cleaning the ecoil under dash I checked it and it was very loose.
    If your not handy bring it to a muffler shop and let them examine the entire exhaust system thats cheap.
    In the meantime go to youtube and look up
    Prius inspection mode
    it will show you how to put the engine in inspection mode and the engine will idle endlessly until you shut the car off.
    Do it at night and while engine running get under the car in the rear sides and look for smoke with a good flashlight.
    Easier to see at night.
  4. Mendel Leisk
    38,651
    Another possibility: check that oil fill cap is on.
    Don't ask how I know about this one...
    edthefox5 likes this.
  5. edthefox5
    10,096
    4,804
    Clearwater, Florida
    lol...yes its happened to all of us...
