Oil Pan Bolt size?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Mar 17, 2023.
  1. MrPete
    MrPete Active Member
    477
    187
    Colorado, USA
    Context ASAP, but for now...
    I likely need to remove/replace my oil pan. What size are the pan bolts? I found cheap plastic "pop ups" that make pan replacement easy, and want to order the correct size. :)
  2. Mendel Leisk
    40,574
    are you talking about the black metal pan at bottom of engine? Definitely no “plastic pop-ups” holding that. Install details in first attachment.
    look on parts.Toyota site?
    If this for plastic under-panel, under the engine bay, plastic pop-up fasteners abound; see second attachment.
    #2 Mendel Leisk, Mar 17, 2023
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,589
    5,888
    Texas Hill Country
    Are you talking about the plastic undercover?
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,352
    2,346
    Taylors, SC
    Oil pan bolts have 10mm hex heads. The actual threads are M6x1.0.
    MrPete likes this.
  5. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    Maybe order by part number, 90119-06848 for OEM bolts 9 in total, 2 nuts OEM 90179-06326.
  6. MrPete
    477
    187
    Colorado, USA
    THANKS! So, I will buy some 6mm plastic snap-ups to make reinstalling the oil pan easier:
  7. MrPete
    477
    187
    Colorado, USA
    As you can see, I wasn't talking about something that's permanent ;) ... just an aid for reinstalling the oil pan itself.
    I was a bit surprised that the oil pan instructions don't happen to mention the bolt size! But thanks to others here, I've got it... and have the snap-ups (sorry, not pop-ups) on order.
  8. ChapmanF
    17,326
    What on earth would be the purpose of attaching the oil pan with anything other than its original steel bolts and nuts? Surely you won't operate the engine that way??
  9. MrPete
    477
    187
    Colorado, USA
    Wow, people make a lot of assumptions. Take a look at the product. It's simply an alignment tool making the job simple for one person.
    • screw in four locations
    • slide the pan into place; it clicks up against the upper pan
    • these hold it gently aligned with those (four) holes
    • insert the other N bolts
    • then unscrew the plastic snap-ups, add the final four bolts
    No fuss, no muss. Oil pan goes in quickly, perfectly aligned, easily accomplished by one person.
  10. rjparker
    9,589
    5,888
    Texas Hill Country
    It appears to be a temporary alignment guide and method to hold the pan. Then removed one by one and replaced by a bolt.
  11. MrPete
    477
    187
    Colorado, USA
    Exactamundo :-D
    Some people use just two... whatever. And I'm sure 6mm plastic bolts can be found cheap somewhere... but these are designed for this purpose, and in this case I don't want to mess around nor miss on getting it in place correctly... somebody apparently already got it wrong (most likely... will know once I've got it apart!)
  12. ChapmanF
    17,326
    Oh, I see you mentioned an amazon product in there, B000CSEQY6.
    If you're not careful with how you enter amazon links on PriusChat, the forum software will turn them into three-inch blank spaces for some other readers (like me), depending on their browser security settings.
  13. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Yes, so you won't need three hands to keep both ends aligned while holding it up and starting the first bolt.
  14. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Same here - I was trying to figure out what the OP was talking about until I entered the product number in Amazon. Then I went to YouTube and finally saw how to use these things. Now I can sleep at night ;). Thanks @ChapmanF!
  15. ChapmanF
    17,326
    The key is to create a link yourself the usual way, where you supply both the URL and what you want the link to say, like here's the amazon thing I'm talking about. The forum software leaves that the way you wrote it.
    But any time you just go dropping an amazon link by itself into a post, the forum software goes "oh yummy! another amazon link I can turn into a three inch blank space so other people reading will wonder what you're talking about!".
    I guess the people reading who use more lax security settings in their browsers actually get a little all-singing, all-dancing three inch tall amazon ad for the product, instead.
  16. Mendel Leisk
    40,574
    Yeah this is what I've noticed, and I'm one of the 3" of blank space types. So: "bare" Amazon links are blanked, for some (with laxer security settings?), and Amazon links "embedded" in a word string are ok.
    I wonder if there's a technical reason this situation is advantageous? Or it's just a vagary of the current website software? I know it's frustrating.
  17. MrPete
    477
    187
    Colorado, USA
    Strange! I see the link, and the 3 inch blank is a photo. No song and dance. Just a picture
    Not changed by forum software. My guess: you have a browser ad blocker...
    I am surprised that putting text with it breaks the ad blocking!
  18. MrPete
    477
    187
    Colorado, USA
  19. MrPete
    477
    187
    Colorado, USA
    I see:
    - clickable image
    - then 3 links
    - then image
  20. MrPete
    477
    187
    Colorado, USA
    BTW, on 2011 it is ten bolts, 2 nuts
