Oil plug washer really necessary?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriBeeee, Feb 14, 2013.
  1. PriBeeee
    PriBeeee Junior Member
    Madera, CA
    2018 Prius
    I've owned my 2005 Prius for four years and there was no washer on the oil drain plug when I first changed the oil and I've never used one. The car has never leaked one drop of oil. Has anyone else had this experience? Or am I the only one foolish/lucky enough not to have needed a washer on the drain plug? I'm getting ready to change the oil and am wondering whether to use a washer this time.
    52,404
    don't jinx yourself.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Well they put one on at the factory so why not continue.
    52,404
    are they expensive?
  5. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Yes! Its commonly called a crush ring. Its designed to provide a seal between the oil pan and the plug. It is important to use a calibrated torque wrench and use the torque setting in the manual. If on over torque occurs serious damage can occur to the drain pan. That will cost big $$$$. It is recommended that every oil change should have a new crush ring, because it has already seen the compression. They cost like 1$.
  6. Tim Bender
    Tim Bender Member
    134
    44
    They are like 10cents each, but I've never changed the original crush washer that came on my motorcycle, and after 40,000mi I've had no problems.
    GT-N8013 ? 2
  7. Mendel Leisk
    41,925
    There might be one on there, firmly bonded to the underside of the bolt head. Next time you have the bolt off, see if there's something you can separate with a thin blade screwdriver.
  8. pjc
    pjc Member
    139
    46
    Bloomington, MN
    Don't bother -- get yourself a Fumoto valve and never worry about that plug again.
    cyberpriusII likes this.
  9. ETC(SS)
    7,367
    HOLY CRAP!!!!
    That washer is critical!!!
    Your car won't last for a week without one installed.
    You're going to wreck your motor and then you're going to have to replace your car with an earth-killing non hybrid....
    Fossil fuels will be further depleted and ecologically tragic "oil wars" will be waged over the remaining dregs killing tens of millions....
    Global temperature will rise causing disasters of biblical proportion....
    Some bitter religion hater will see the word "biblical" in a non-FHoP portion of the forum and run screaming to one of the mods with tear stained cheeks...
    Do you really want that on your conscience????
    Of course.....since your car is an 05.... ;)
  10. Mike500
    Mike500 Senior Member
    2,593
    767
    Basically any 12mm washer will do.
    And, while Toyota recomends 28 ft. lbs. for the torque value, which is standard for M12x1.25 threads, 18 to 20 ft. lbs. is sufficient.
    Tigntening the plug, which is a bolt, tensions it like a rubber band to hold it in place.
    The washer provides both a sealing element and friction to hold the plug in place.
    I prefer 18-20 ft. lbs., as it lengthens the life of the threads of the welded on nut in the oil pan.
  11. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,840
    Hyampom
    I say, follow PJC's advice, go fumoto.
  12. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I've got ten, and to be honest I only replace them every four or five oil changes. If you PM me your address I can mail you a couple.
  13. cyberpriusII
    1,157
    1,840
    Hyampom
    Some day, I suppose I should get a torque wrench. I know it helps to keep from crushing gaskets, etc.
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yep, it wouldn't be the first time someone thought that they weren't using a washer and it was just firmly stuck to the drain plug the whole time.
    The washer costs about a dollar here, though I'm sure they could be had for less. And though you're supposed to change them each time, if you're reasonable careful with your torque levels then it's generally safe to re-use them many times. So yeah, there's no real reason not to use one.
    BTW. The ones supplied by Toyota have a blue nylon coating, and if the coating still looks reasonably intact then I just can't be bothered to go get another. I've probably used the one currently on my Prius for about the last five oil changes. Never had any leak problems.
  15. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    A washer is, what, 10-20 cents?
    How much of your time ($$$) is wasted if you end up with an oil leak because you're too lazy to replace the washer?
    If you're working for any more than 40 cents an hour, you're wasting money with your proposition.
  16. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Are you replying to me or the OP? If it's me then the precise amount of time I've wasted in 35 years of doing my own oil changes is 0 hours, 0 minutes and 0 seconds, because I've never had a plug that's leaked. Like I said, I only re-use the washer if it's serviceable and I have a 100% record of being able to judge that.
  17. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    When I did mine, I simply followed the procedure in the manual. Verbatum complience. im a neat knick. Old school is fine for my dad, I like the satisfication of knowing I did the job as prescribed by the manufactor.
    There are many ways to get a job done. I tend to be overly into perfection. Not always a good thing. However it's me. Example:
    I run the engine to warm up the oil a little.
    User the exact box socket, or box wrench,
    wipe everything clean,
    use a new crush washer,
    torque to set point.
    The old man grabs a crescent wrench, uses old washer, maybe even the right one, not sure about that. He's just is a getter dun guy. That drives me crazy, but you know what? I drive him crazy too. LOL
  18. maestro8
    471
    109
    nor cal
    Good for you. You want a cookie?
    It's like using a pogo stick in a minefield. Sure, some folks will make it through fine. But it's horrible advice to give to anyone.
  19. uart
    uart Senior Member
    4,220
    1,211
    Australia
    No it's not rocket science. It's not something that only I can get away with but nobody else (because I'm a rocket scientist). If you look at the washers they're nylon coated, and as long as the nylon coating is intact then they're not going to leak. End of story.
    And you're way overstating the risks of leak. Even if I took a crush washer and mangled it with a hammer or something, just the threads on a correctly torqued plug will ensure that the oil will at worst only drip out.
    And finally I was giving that advise to the OP who claimed to not be using any washer at all. Trying to encourage him to put one on. Even if it's re-used several times it got to be better than none at all.
  20. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Even if the nylon coating is a bit ripped (up to a point) it'll be fine. It just needs to compress such that it forms a seal.
