Oil recomendations newbie
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by iron-icman, Jun 25, 2017.
  1. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Hi peeps just bought my Prius 2008 model gen 2 love it.
    Just done a few checks well looking at what's high and low everything seems ok just oil seems a bit low. I have no idea what's in there at the moment what would you do to top it up what would you use. It recomends I believe 0-30
    I will be taking it to Toyota for a full service and battery health check in the next few months just to check everything and get a service stamp thank you in advance. Oh and it has 97,000 miles on
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Then use that.
    BUT.....if it is not near the "add" mark yet, just leave it alone and keep an eye on it.
    It does NOT need to be "full" all the time.
  3. Mendel Leisk
    41,901
    It's 5W30.
    If it's missing manuals, you download. Google "Toyota Techinfo", pretty much first link, and go to Manuals" tab.
    Oil spec is probably also on the filler cap.
    Personally, I would not let the oil get below halfway before topping up, but then I do the same with the gas, lol.
    uart likes this.
  4. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    It's pretty much below the last notch so I cleaned it and left the car running for a few mins and checked again but yes still low I won't do any damage to it will I if let's say it was 0 30 in it and I put a 5 30 in it just because I don't know what's originally been put in however before it's always been serviced by Toyota
  5. Mendel Leisk
    41,901
    AFAIK there's no problem mixing oil weights.
  6. Sam Spade
    2,036
    1,023
    2017 Prius c
    You do know that the engine should have been OFF for a few minutes before you check the oil........right ??
    No, mixing in a few ounces of a slightly different oil will NOT cause any problems.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    There's no such weight as 0-30. If the car is new to you go get the oil changed.
    As far as routinely checking oil level Let the car sit overnight and before starting the car measure the oil. Takes a Long time to let all the oil drip down to the pan.
    If you shut off the engine and immed measure it will always show low.
    The engine holds 3.5 quarts with a new oil filter change. The engine could care less if you mix all 3.5 oil weights. What the engine does care about very much is driving around with the oil level very very low and below the last notch is very low,
  8. orenji
    orenji Senior Member
    5,887
    3,488
    Edthefox5 it's important you Verify, before you give out information. There is 0W-30 weight oil, I use it. Mobil 1 makes it, and I am sure others do as well. You can get a accurate oil reading within 5 minutes of shutting down the car. Some manufactures recommend you don't measure the oil cold. But I do measure it cold and hot, and see no difference. So not sure the thinking behind that.
  9. Mendel Leisk
    41,901
    One thing when checking oil, pull out and wipe the dipstick, then wait, say 5 minutes. Maybe check the tire pressures? Then reinsert and check the dipstick, it'll be a lot cleaner and easier to read: the dipstick is prone to draw oil up the tube, making it hard to read. The delay gives the oil time to drain back down.
  10. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
  11. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Thank you all for your help so I'm looking at topping it up with 5 30 then is that the best and fully synthetic
  12. Sam Spade
    2,036
    1,023
    2017 Prius c
    You aren't absorbing what is being said.
    There is no "best" oil for topping up when it's a little low.........UNLESS you know what was put in there on the last change.
    There is NO 5W30 that is not synthetic......so yes, any 5W30 would be fine, even synthetic blend.
  13. Mendel Leisk
    41,901
    Not that it matters, but I'm pretty sure there are non-synthetic 5W30. (n) I have been buying non-synth 5W20.
    But either way, I think it doesn't matter, there's no harm in adding non-synth if it's synth in there.
    Raytheeagle and edthefox5 like this.
  14. Sam Spade
    2,036
    1,023
    2017 Prius c
    And I'm pretty sure that there isn't. But I guess you are too far north for a "Mexican standoff". :ROFLMAO:
    5W20 is just really thin oil. Synthetic expands the viscosity range.
  15. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Yes I think I have finally got it guys sorry ha ha
  16. Currahee
    Currahee Member
    103
    34
    CT
    There are plenty of conventional oils in 5W-30, Toyota even has one.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Here's the oil I have been putting into our 1998 Toyota 4Runner with 263 k miles on the clock:
    Hope that helps(y).
  18. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    What country are you in, Sam? In the United States just about every major oil manufacturer has a conventional 5W-30 motor oil. Just looking at WalMart: Supertech, Mobil, Castrol, Valvoline, Penzoil, Quaker State, and Havoline all have conventional 5W-30 motor oils. Or are you trying to say that even conventional motor oils these days have synthetic bases?
  19. Sam Spade
    2,036
    1,023
    2017 Prius c
    I was obviously operating with OLD information.
    Sorry.
  20. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Thank you for your help went to my local Asda and got the 5 -30 one fully synthetic so will put that in for the moment as next few months going to take it to Toyota for a full service
