oil spill... did they kill my car?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bjg, Jul 25, 2015.
  1. bjg
    bjg New Member
    south carolina
    help! last week i took my year old 2014 prius 2 in for scheduled maintenance- which included oil change. on my way home, i noticed i was "smoking". i pulled over to be sure i wasn't on fire & discovered i was loosing oil. i turned around & drove back to the dealership. i was ~20 miles in the country. the yellow exclamation point and "low oil pressure" kept beeping & flashing until towards the end they came on & stayed on. i limped to the dealership with hybred alert on & they had to admit that the plug was cross threaded. after changing the oil pan & plug & felt door pad, they are trying to tell me that this car is totally fine and as good as new. i drive over 450miles each week for work & at least twice a year drive 1000 miles one way without stopping- a 16 hour trip by myself. i don't trust this car anymore.... would you? oops, wrong prius type, went to correct one
    #1 bjg, Jul 25, 2015
    49,471
    welcome! no, contact toyota directly. and if they won't give you satisfaction, a lawyer. at the very least you should get free oil changes (not sure i'd want them changing my oil) and a lifetime engine warranty. at best, a replacement engine now. all the best.(y) maybe send it to blackstone for testing.
  3. bjg
    bjg New Member
    south carolina
    49,471
    no. tell them you want a new engine, and contact toyota directly if they don't comply.
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    I had a similar with mine. Holy Crap | PriusChat Talk to the Service Manager directly. Have everything documented and in hand. Call Toyota and open a case. Mine was handled correctly, but you can not assume your local will do the same.
    Edit...I never had the light, you however should have not driven any further when you noticed the smoke and light/s.
    #5 frodoz737, Jul 25, 2015
    Priusguy78213 likes this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    7,967
    4,711
    Texas Hill Country
    I would file a written complaint with Toyota by certified letter and then check my oil consumption weekly. Probably is ok since it uses full synthetic but if you can get an extended warranty out of them, you are better off. Obviously the best thing to do when you have low oil pressure is to immediately shut it off and get a tow.
  7. John Bergendahl
    102
    17
    gulfport,ms
    New engine !!!! If they tell you everything is ok and couple of years after you are out of warranty the engine go bad you don't want to have the thought in the back of your mind its because of this !
  8. bjg
    bjg New Member
    south carolina
    yeah, well i'm gonna plead ignorance...... i've learned alot this past week ... the hard way
  9. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I would notify Toyota customer care and demand to watch them change the oil in 3000 miles, bring your own clear glass container for them to drain it into and a good magnet, if the magnet attracts bits of metal from the oil your motor is damaged.Id record the entire oil change...but in reality you should have called the dealer and had the car towed at their expense ..
  10. seckwielen
    seckwielen Member
    112
    26
    As I do not hold the oil service location harmless. They did cross thread the plug. I think driving on the leak and smoke was a huge mistake. 20miles??? I would have contacted the service location and had them send out a technician to diagnose the problem. Maybe an on site correction and a new pan and plug later. But driving 20 miles with a clear low oil condition, I think they have some fuel to to have you partially responsible as well.
    SAMSUNG-SGH-I337 ?
  11. Former Member 68813
    3,524
    981
    US
    one is not supposed to drive without oil no matter whose fault it is.
  12. bisco
    49,471
    however, if one is ignorant of the consequences, that may mitigate the fault of the o/p.
  13. JTM2955
    JTM2955 Active Member
    475
    185
    At the first sign of trouble, I would have first called the place tell them to send a wrecker and rental.
    Its not your job to even think about what happened. But if you continued to drive after the oil pressure warning lamp turned on, they MAY have a point.
    Get Toyota HQ involved. They should be able to resolve this. If not, lawyer up and sue them.
    LG-D851 ?
    NickInNJ likes this.
