Oil Washer
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Spenny, Feb 3, 2018.
  1. Spenny
    Spenny Member
    86
    28
    I feel a little embarrassed asking but is it ok to reuse the oil washer? I have my car on stands right now and I really need to change my oil but I can find my stash of new washers and it’s 10:51 at night.
  2. JC91006
    16,933
    8,643
    Yes it's ok to reuse, some people never change them
    Tande and Raytheeagle like this.
  3. Mendel Leisk
    42,271
    Just the once is no big deal.
  4. Spenny
    Spenny Member
    86
    28
    Thanks. I figured it shouldn’t but I’d hate to do something stupid, lose my oil and ruin my engine.
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    nothing like a stupid question/
    better safe than sorry/
    pilotgrrl likes this.
  6. padroo
    padroo Senior Member
    2,763
    2,253
    You can order them on Amazon and if you reuse the old one inspect it an most of all make sure it is there. If you buy new ones make sure you don't double washer them, it's been done i'm sure.
    I can see a problem with the newer Prius with the larger plastic shields under the car. If you have an oil leak it will take you longer to detect.
  7. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    i have 100k miles on my original washer
    Tande and padroo like this.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    There’s 3 types of washers I’ve used before. The aluminum and copper, I reuse it 3 times and toss it away. The nylon washer Toyota uses when changing the oil, I don’t reuse them. The factory washer that Toyota uses when The vehicle is brand new, I’ve seen people never change them out. I just like to change out my washers every time if it’s those nylon crush washer, they’re soft and tend to break after the 2nd time since they’re a softer material.
    pilotgrrl and Raytheeagle like this.
  9. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    I am still using the same oil washer that I bought new with 40K on the car. Also bought three extras. My car is now approaching 120K.
    NutzAboutBolts likes this.
  10. Tande
    Tande Active Member
    551
    337
    Mich.
    Doesn't a new washer come with ea. new filter?.......at least with my OEM Toyota filters it does.......
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Some do, some don’t. When I bought the six pack off of eBay for our 2010, no washers.
    When I bought a single filter for our 2017 RX450h, they put a washer in the box so the techs have everything they need in one box;).
    But they charged $2.20 for the gasket:mad:.
    Lesson learned(y).
  12. Mendel Leisk
    42,271
    i change the washer every time, but if circumstances ever dictated, I'd have no qualms about single reuse.
    No problems with the Toyota washer, with it's laminated plastic skin. BUT: Honda has a similar laminated washer, I would torque it, and next oil change the bolt seemed barely more than finger-tight. I mentioned to the part guy, and they came up with some plain aluminium ones, no problems with them.
  13. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Still using my original washer as well. I do have 5 or so in a bag somewhere in the glove box. The ones I purchased look the same as the original. Oh, except they don't have oil on them. ;)
  14. Mendel Leisk
    42,271
    You guys are living dangerously, lol.
  15. padroo
    2,763
    2,253
    I haven't changed oil yet on my Gen4 but have several left over from my Gen 2. I don't know if they are the same or not.
  16. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    The drain bolt should be the same.
    It is on the RX450h and was the same one on our old 98 4runner.
  17. NutzAboutBolts
    1,756
    1,784
    Bay Area
    Toyota, Lexus and Nissan drain bolts are all the same from what I remember.
  18. Mendel Leisk
    42,271
    Honda automotive oil filters (all, as far as I know) are same socket size as Prius, 14 face, 64 mm face-to-face. Is that standard size for all Toyota?
  19. David Beale
    5,963
    1,989
    Edmonton Alberta
    Just a note for those who fret about the washer. The first oil change on the FJ Cruiser went badly as I was confused. When I put the drain bolt back in and filled it with oil everything looked fine. No leaks. Started the engine and warmed it up for a minute or so and checked again for leaks. There were none. Proceeded to pour the oil from the catch pan into container(s) and lo and behold, there was the drain bolt washer in the bottom. Still no leaks on the FJ. I did clean the drain pan, remove the drain bolt, install the washer and replace the bolt (with clean oil flowing - lots of fun).
    So I'm not so sure a "faulty" washer would lead to disaster. ;)
  20. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    -12028 washers are the plastic/nylon ones, -12031 are the coated metal ones.
    The latter can be reused, but should not be.
    Most quick lubes never change the washers unless there is a leak. You can also buy the generic washers off eBay for much less than the dealer, but I find them to be a bit thinner and are not reusable.
