Oil
Discussion in 'Gen 4 Prius Technical Discussion' started by modeladay, Dec 30, 2019.
  1. modeladay
    modeladay Junior Member
    Lincolnton,ga
    What are your thoughts on using 0-30 oil as opposed to the recommend 0-20? I live in the south where temperatures most of the summer run in the 90s and above.
  2. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    Go ahead, might loose a couple mpg but others have had good results with oil burners
  3. Mendel Leisk
    41,926
    Or 5W30? Maybe easier to find, was the 2nd oil spec.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Australian manuals show this:
    10W/30 is what my TOYOTA dealer's invoice shows they use.
  5. modeladay
    Lincolnton,ga
    I can get 0-30 here at Walmart so its not to find, I was wondering if there was an advantage to using it considering the over all hot weather? I wouldn’t mind giving up a little mph if the result would be better protection for the engine.
  6. alanclarkeau
    7,045
    7,593
    This is TOYOTA's recommendation in the manual with your car - it's your choice once a car is out of warranty - you could ring TOYOTA and ask their opinion.
  7. Mendel Leisk
    41,926
    Or before? Toyota recommends a viscosity, but it's not a strong caution. Doubly so considering your Australian Manual with it's gamut of grades, even though they still recommend 0W20.
    The last line you quoted, talks about moving up to higher numbers under certain conditions.
    For all my talk, I'm Mr OW20 so far, lol.
    alanclarkeau likes this.
  8. ETC(SS)
    7,367
    Won't hurt.
    Won't help.
    The oil temp in your engine is the same in summer months when it's over 90 in Jawga as it is when it's under 32 during the winter months.......probably somewhere around 190-degrees.
    Engine temps are critical in judging whether or not your coolant temperatures are within proper ranges which is why the temperature gauge in a Prius is as big as it isn't. ;)
    If you will notice the arrow in the picture above, it extends beyond 80-degrees.
    If 90....or 100....or 110 represented a problem with the oil I'm thinking that there'd be a vertical stop with a message saying:
    "Hold up there! t's getting HOT!! Better club up to a 0w30 or 40!"
    There isn't...
    Despite claims that global warming is going to kill off the human race - I do not think it's ever going to get over 190-degrees in the largest state east of the Mississippi....or in Death Valley....or the Gobi desert, or anywhere else you think that you need to run thicker oil.
    If you have a 3-4 year old car and you don't check your oil level as often as the manual suggests, you might experience greater oil use after 100,000 miles - but for properly maintained cars in North America, I'd say that there's not going to be much of a difference by going up or down one grade.
    As always.....
    YMMV
    #8 ETC(SS), Dec 31, 2019
  9. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    I have similar temps here and use 0w-40 and get oil pressure of 30-50 psi. Can't imagine using 0w-20 but nobody has actual pressure readings w it to show what they get. If u used 15w-50 and started up in 40 degree weather the pressure goes high enough to rupture the pressure sending unit
    Anyone know if the pump has a hi/lol pressure autoswitch?
  10. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    If it were any other car, I'd say your concern may have merit. I've been around cars long enough to see that Toyotas when run by the specs often have engines that outlast all other brands. I've seen that both up North, and in an area farther South than you are - third-hand to sixth-hand Toyotas barely maintained by people who would not buy synthetic oils, let alone change the oil regularly. It's why I made the switch this time.
    My take is that oil quality goes farther to protect the engines than does viscosity these days (when talking about a change of 10 up or down). It's when someone uses a lower grade oil, something closer to dino-oil of days gone past, where viscosity meant a measurable amount more than did the quality. The best synthetics out there both out-flow (in cold weather) and out-perform (in wear) their direct synthetic competitors for the same viscosities.
    Doug McC likes this.
  11. beef jiggles
    beef jiggles Member
    136
    34
    Colorado
    Toyota is well aware they sell cars in hot climates. 0w20 is just fine. These engines have much tighter bearing tolerances than the old garbage American style engines most people learned on.
    #11 beef jiggles, Aug 2, 2022
    jerrymildred, Tande and Mambo Dave like this.
  12. Doug McC
    Doug McC Senior Member
    1,083
    423
    Midwest
    2022 Prius
    Just out of curiosity, how many miles does the Prius have on it, and how many have you put on it? Just curious because if things have been working, why change now. And FWIW, does anyone else notice that strange word "must" in the statements in the manual regarding oil weights? The oil does a lot more in modern engines than just lubricate the moving parts, and what has been working for those with Gen 3's may not work for Gen 4's.
  13. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    which are the best synthetics in your opinion? i've always driven beaters before but i want to baby my prius : )
  14. Rmay635703
    2,669
    1,694
    2013 Chevy Volt
    In the US there is no legal definition of Synthetic.
    So as long as the “synthetic “ oil meets the spec and is changed often <5000 miles you should get good wear numbers.
    The type of oil is less critical than the change interval, again so long as it meets the spec.
    That said the best synthetics tend to be the Euro rated 0w40 which have the most synthetic, best add pack, and the highest TBN. Close second is Mobil 1 ESP
    Unless your PRII specs 5w30 or is an oil drinker Euro oil 0w40 isn’t needed for a long life
    This place is a good one to talk oil.
    https://bobistheoilguy.com/forums/
  15. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    what spec is that? how do i determine if a particular brand of "synthetic" oil meets this spec?
  16. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    You're worried about meeting specs when the dealerships aren't. Buy quality and be done with it.
    I've now worked for four dealerships (never a Toyota, but yes to Honda), and most places use bulk oil that they'd rather not name.
    This prior Toyota tech knows:
    Doug McC and douglasjre like this.
  17. Rmay635703
    2,669
    1,694
    2013 Chevy Volt
    Your owners manual and even oil cap list
    SN Synthetic in 0w20 or 0w16
    (depending on year and region)
    Each year may vary slightly but the manual is king.
    So open up your manual
    the spec can be any number of things including a Toyota spec
    But Usually Ilsac, SN, SN+ or SP Is the spec
    0w20 or 0w16 is the weight/grade.
    So any synthetic on the shelf at the correct weight will work. (Most exceed gf5)
    Modern synthetic graded oils from a large national chain (that aren’t from a dollar store or gas station convenience store) all meet the spec for a gasoline car.
    Believe it or not Mobil 1 from Walmart works great even though it’s not the greatest, extra most bestest boutique oil
    wear and tear won’t be measurably different even though it’s less expensive.
    Like I said if you want to get into the weeds go to bobistheoilguy.com
    But these days all major brand synthetic oils meet the spec and it’s not hard to verify
    #17 Rmay635703, Aug 4, 2022
  18. ColoradoBoo
    ColoradoBoo Senior Member
    1,272
    880
    Monument, Colorado USA
    My philosophy is if it ain't broke don't fix it. Toyota engineers know their stuff and a ton of Yotas out there still plugging away at 300,000 miles using the oil viscosity printed on the fill cap.
    The best thing we can do for our cars is regular maintenance with the best being engine oil changes.
  19. Doug McC
    1,083
    423
    Midwest
    2022 Prius
    Very Well Said!
  20. Doug McC
    1,083
    423
    Midwest
    2022 Prius
    VERY WELL SAID!!!!
    Mambo Dave likes this.
