OK, here's a question for those readers far more knowledgeable…
Discussion in 'Gen 2 Prius Technical Discussion' started by WilDavis, Sep 17, 2017.
  1. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    …than me about the innards of the TractionBattery. I've set up one of my ScanGauge-IIs to have one of the X-Gauges as the "csd" (delta state of charge between all the modules) which (so far) has always shown 0%. which I think (hope) to be A Good Thing. Does anyone know exactly what the csd displays (is it the delta of the modules, or each individual cell), and is my assumption correct? …and at what reading should I start getting worried? @jeff652 ? …anybody? Thanks in advance! :)
    49,430
    no offense wil, but you're the guru. :cool:
    WilDavis likes this.
  3. WilDavis
    2,492
    2,153
    49
    …are you saying I've guruwn into the role, even with my limited experience? …but thanks, I feel honoured, indeed! ;)
    49,430
    physician, heal thyself.:)
    Raytheeagle likes this.
  5. WilDavis
    2,492
    2,153
    49
    …great suggestion! Now, Dr. bisco, are you able to do anything for, er, um… …ED???:eek::rolleyes:
    bisco and Raytheeagle like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    I operate under the "ignorance is bliss" mantra ;).
    Since there's "not much I can do about it" other than worry, I watch the road and impatient drivers zooming in and out:).
    After @Mendel Leisk experience with the OBD port, I keep mine free of stress(y).
    bisco and WilDavis like this.
  7. bisco
    49,430
    ED = electric drive?(n)
    WilDavis and Raytheeagle like this.
  8. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    At least you kept that acronym in the car realm ;).
    Mendel Leisk, WilDavis and bisco like this.
  9. Mendel Leisk
    38,702
    Used to be old age, now it's a dysfunction... :rolleyes:
  10. jeff652
    jeff652 Senior Member
    606
    623
    Idaho
    Well I have not used that x-gauge, but I can tell you it would be voltage delta between blocks, not cells. The car does not monitor individual cell or module voltage. The lowest level the car goes is blocks (one pair of modules is a block). If it's always zero I would question the x-gauge itself. There is always some amount of variation between blocks/modules/cells, so it should be showing something.
    Raytheeagle and WilDavis like this.
