OK, here's an easy one we've all seen
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Nov 11, 2023.
  1. ronlewis
    ronlewis Active Member
    876
    178
    texas
    2001 Prius
    Any tips/suggestions for fixing/replacing/eliminating the fabric on our door panels that always peels off when it gets old. Usually leaves a lot of its sponge backing still on the door panel. I have one now that is coming off intact, and the clean door panel looks as good as the old fabric.
    I've done that to others, just removed the fabric and cleaned the panel up. But, I'm thinking they probably sell this fabric somewhere, such that we could just clean the panel all up then glue down the new fabric just like the factory.
  2. Trombone
    Trombone Member
    195
    69
    Allentown, Pennsylvania
    2002 Prius
    I had this problem on the driver's door, with the fabric coming loose at the top. I used white glue to affix it back where it belongs. White glue is water soluble so the "fix" is reversible, if need be. So far it's holding fine.
  3. ronlewis
    876
    178
    texas
    2001 Prius
    I'll try that, George Costan...I mean Tbone. The fabric never seems to tuck back in smoothly, so maybe the glue holds it in place so it doesn't back out of the groove.
