ok, Prius Prime going downhill in the rocky mountains
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, May 31, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,638
    Farmington Hills, Michigan
    Question: when going downhill what's the most efficient? Putting the car in charge mode at the top of the downhill descent, or just drive the car in regular HV. will regular HV (after EV has depleted many miles ago) completely recharge the battery to approximately 30 miles EV or charge mode at 80% capacity (20 miles EV)
    lx.josh likes this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,017
    Westminster, Colorado
    Depleted battery, Ev mode, B mode on the hills would be my guess from doing smaller hills.
  3. dalcon95
    dalcon95 Senior Member
    512
    652
    Easley, South Carolina
    Yes. What Lee Jay said. EV mode with B drive mode and apply brakes when it in needed.
    #1 in Easley,SC
    priuscatprimeguy and joachimz like this.
  4. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    like @Lee Jay and @dalcon95 said ... on my recent trip, going down a 5+mile 6% grade i gained ~11EV miles, freeway with DRCC set @ 65
    dalcon95 and priuscatprimeguy like this.
  5. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    B Mode is engine braking mode. If you will be "full" at the bottom of the hill, then it is in your best interest to use B mode to WASTE energy spinning the gas engine as an air pump as well as putting a little bit back into the battery. There are some mountains where you will definitely fill up the battery, and B mode should be used even on a Prime. In general though, just keep it in D mode. When you use the brakes lightly it will still be regen and fill the battery.
  6. dalcon95
    512
    652
    The engine is not used as a brake on the Prime when in EV mode and B mode until regenerating EV range has been exhausted. When in EV mode and B mode, the regenerative braking is increased which requires less foot pedal braking and is all regenerative unless you press the foot pedal brake to hard to cause the hydraulic brakes to work. In this situation, the engine does the same as it does at any other time the engine is in EV mode until the regenerating EV range is exhausted and you have a full EV designated portion of the battery. After that, energy is wasted because it has no place to go, which engine braking doesn't matter at that point other than to prevent less use of the hydraulic brakes. Prime operates differently than the liftback Prius in this regard because of the EV mode perimeters set on the Prime versus the liftback limitations. I personal experienced this myself.
    #1 in Easley,SC
    #6 dalcon95, Jun 1, 2017
  7. giora
    giora Senior Member
    1,966
    729
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Can EV mode be activated with depleted battery? With the PiP you cannot switch to EV until some regeneration is completed and EV estimated miles appear.
    With the PiP, in the situation described by the O/P you better start the downhill in HV with brakes (no B) until you can switch to EV+B, somehow I suspect it is the same with the Prime?
  8. dalcon95
    512
    652
    If you can't switch to EV mode right away, that will work. Soon as you are in EV mode, put it in B mode.
    #1 in Easley,SC
  9. Lee Jay
    5,850
    4,017
    When I said "depleted battery", I meant a battery with sufficient remaining capacity to absorb the expected regeneration from the descent.
    priuscatprimeguy likes this.
  10. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    Sounds to me same as what I said.
    O/P was specific: he was in HV mode on the top with battery depleted long ago.
    dalcon95 likes this.
  11. Lee Jay
    5,850
    4,017
    Which is no problem because as soon as you start the descent regeneration will put you over the 0.1 mile limit for starting Ev mode.
  12. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    That depends on the battery SOC when on top and can be quite longer than 'as soon as you start descent'. As I said, until you can switch to EV, brakes with no B is your best coice.
    With the PiP, there is a SOC threshold above it the system reverts to EV mode automatically (about 2 EV miles on the estimate if I remember correctly), what about the Prime?
    markabele and dalcon95 like this.
  13. markabele
    5,084
    1,782
    Nebraska
    I took a long trip around the Rocky Mountains last year in my PiP. Filled up the battery pack several times on various descents. You Prime guys will be able to take advantage of even more.
  14. alexcue
    alexcue Active Member
    346
    311
    So Cal
    I can attest that it will recharge to 80% capacity. You won't end up with the same amount as if you'd charge at the wall. Done this several times and while in EV mode but going downhill it will start the ICE to burn off the excess regeneration.
  15. markabele
    5,084
    1,782
    Nebraska
    I guess I don't understand. How is their excess regeneration if it only charges to 80%?
  16. alexcue
    346
    311
    So Cal
    my assumption is that it its a safety for the battery. Unlike wall charge where it trickle charges the final several minutes, brake regeneration is like a slam when it comes to charging.
    Prius from Dad likes this.
  17. giora
    giora Senior Member
    1,966
    729
    2013 Prius Plug-in
    Plus, Charge Mode charging rate is considerably higher than wall charging (it is about 1C rate) so battery is considerably hotter at the end.
  18. priuscatprimeguy
    2,730
    2,638
    perhaps I should have been more specific, I have not yet reached the rocky mountains, as such I am currently in Minot North Dakota, which interestingly on my Samsung Gear watch the elevation has been slowly increasing since I left Duluth it's now at 1923 feet from a low of 750 feet in Michigan. I was asking because I will be eventually going back down. So, drive car continuously while battery is completely exhausted of it's EV powers.Which would mean I would be in HV mode by then. So just continue to coast downhill and the battery will fill up to 80% capacity and then ICE will kick in to burn off excess EV. Am I correct in this assumption?
  19. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    [Beginning of rant] Lots of opinion here, and some deductive logic (which has proven flawed at times. Brain fart ? )
    You will hear about the 80% charge in a lot of different cars that store energy in batteries.
    Batteries get hot while charging.
    The capacity of a battery varies with temperature. Charging batteries can get very hot.
    It's not that batteries are limited to 80%, it's that at very hot temperature levels, the charge level is full at that temperature.
    If you look at the charging current graphs in this forum, you will set that at ~80% the charging takes little pauses. This allows the battery to cool, off, increasing charge capacity, allowing more charge shortly later.
    Some cars don't have that. It's usually due to liquid cooling of the battery.
    Liquid cooling results in a very heavy battery system.
    Heavy car results in bigger wheel bearings, ...more loss.
    I'm glad that toyota has chose to keep the weight down, == lower capacity bearings == better rolling resistance.
    Bear in mind, just because a car is electric, does not mean that it is more efficient.
    AAE (as an example) tesla. Good size battery pack (super heavy). Oversize motors( heavy). Crazy with style., big tires, options.....
    Does not mean that it is an efficient car.
    [end of rant]
    In the prius, charging mode increases the temperature of the prius batteries.
    Any charge mode braking causes an increase of temperature.
    You cannot allow charge mode to use up all of your temperature budget in charging batteries, because that will reduce your regen capacity from braking. Reduces efficiency, good choice toyota.
    Even if the batteries cool down, how can the car predict your braking in the future? It doesn't, it just reserves capacity.
    It's too bad we don't have the obd codes for the batteries for the prime, we have no way to observe this.
    On the 1012 prius, we had all the codes, and I had a scanguage to monitor the batteries.
    On one trip up 495 in ma, the traffic was in one of it's crazy modes.
    Everybody going 70+, then to standstill in a few minutes, the back to 70+, over and over.
    My prius batteries went to a very high temperature, per scan guage. (I dont' recall the temperature).
    At that time, there was no more regen, no more electric drive, I was a full fledged gasser !
    Toyota fully protected the batteries.
    So... when it comes to charging think thermal.
    Unfortunately, we have have no way to measure (no OBD codes) battery thermals.
    jp
    Bri-n-TX and heiwa like this.
  20. priuscatprimeguy
    2,730
    2,638
    let's clear things up, "it will recharge to 80% capacity" in charge mode? or without selecting charge mode? And if both options are available which will give you greater EV range when bottoming out from the descent?
