Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?
Discussion in 'Gen 5 Prius Main Forum' started by REBobBecker, Mar 30, 2024.
  1. Surfbob
    Surfbob Junior Member
    Central California USA
    2024 Prius
    Wow, talk about misinformation...so all of these reports are the owner's fault? Engineers in general "know what they're doing" but are not all-knowing or perfect. If you think otherwise, explain the flaws that show up in things designed by engineers....all the users' fault? No, I think it is the job of engineers to design products that normal people can use without having to take a night course on how to use it, and baby-sit it like the folks on this thread are doing to prevent their battery from going dead.
    I have a '24 non-prime with a bit over 12k miles, bought new and in regular use for varying trip lengths, though no extended trips lately. A couple of months ago I went out to use it and got a "hybrid system must be activated" warning due to a low battery. "Have it towed in", said the dealer, which was ridiculous, as I have other things to do than spend the rest of the day doing something I shouldn't have had to do in the first place. The car had been in use at our other house locally, then the previous day driven the 20 miles home. Plenty of time for any alternator to charge a battery adequately.
    So I charged it a few minutes from under the hood to get it going, then later charged it overnight to get it fully charged (after reading in this forum about all the others having the issue). It's was fine since, but, just in case, I had bought a new jump starter battery, not wanting to be stranded later in some awkward situation. We left at the beginning of March for a 3+ week trip, in which the car would be at the airport, and I made sure to have that jump starter in there with the spare tire I had to buy, which was also not included with the car.
    Sure enough, parked at the airport 24 days, got to the car and saw the same disappointing "hybrid system..." message. Jumped it at the battery and it ran for a couple of minutes and shut off. Now if that battery was "dead", why on earth did the system shut it off so quickly instead of staying on to charge it? However, it did start and stop OK after that, so go figure.
    Now I've been driving and working on cars for 64 years, and have learned over time that 1) A two year old car with 12k miles and nothing left "on" to drain it should not have a dead battery after sitting overnight (and no, I don't leave the key in or around it, the lights weren't on, and also no, I don't pamper it by going out and charging it every night...one should not need to do that if the all-wise engineers were so perfect as some seem to think.
    These cars either have a design flaw that does not adequately charge the battery...a simple voltage regulator and alternator are smart enough to know how to charge a battery, they've done it for many years. Or, the batteries they're putting in aren't adequate for the job or are defective. It's that simple. For someone to imply that this is "normal" and it's just improper maintenance or dumb people using their car improperly, is ridiculous.
    #401 Surfbob, Mar 28, 2026
    mingc likes this.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,387
    537
    New York State
    2026 Prius
    I've said this before, but the $26 bluetooth battery monitor is still providing entertainment to me. Then again, I never felt the need for one before this car, and I'm no spring chicken. Maybe there is no need, but again, it was cheap and I feel informative. For instance:
    2023p and Gokhan like this.
  3. Gokhan
    Gokhan Senior Member
    6,663
    2,641
    Paramount CA
    It is not necessarily your fault. As I said, chances are that your car sat at the dealer’s lot for too long before it was sold, which degraded its 12-V battery. The dealer should have charged it periodically and definitely before sold.
    As I keep repeating myself, once the SOC becomes too low, the battery is not only degraded, but also the BMS will not properly charge it, leading to a downward spiral.
    Leaving these cars undriven for three weeks is too long, even with a healthy battery, let alone a degraded battery as in your case.
    Since your battery is already degraded and you don’t seem to be driving much, I would recommend upgrading to the Uplus AGM battery on Amazon and also getting the BM2 battery monitor on Amazon @VelvetFoot mentioned.
    In any case, there is nothing special about the Gen 4/Gen 5 Prius. All newer cars occasionally experience similar 12-V battery problems.
    Blackat and 2023p like this.
  4. Blackat
    Blackat Active Member
    485
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I've resigned myself to "it is what it is" with the battery. Got the NOCO Genius and trouble free
    schja01, Bob P., Tekz and 1 other person like this.
  5. Bob P.
    Bob P. Junior Member
    Western PA
    2023 Prius
    LE AWD-e
    Yes, we were in FL for three weeks in February, and it started OK when we got back to PA. When we got 13 inches of snow it sat for a month, but I started it once to make sure the battery kept charged.
  6. Mendel Leisk
    42,148
    That's a little optimistic. A month long hiatus with one drive is going to take a toll. For something like that it's better to either disconnect the neg cable, or (if practical) keep it on a smart charger.
  7. bisco
    52,662
    when we left for Florida, I had a senior moment and connected the maintainer ground clamp to a non grounded bolt :eek:
    got home 3 months later and the battery was 11 volts. I charged it up, and have been tracking it every morning.
    so far, back to 12.7v after 3 weeks
  8. GeoJ
    GeoJ Active Member
    225
    203
    United States
    Is disconnecting the negative cable recommended, or, does it solve the problem of leaving the car for a month (or, perhaps a few weeks)? Seems like an easy solution if you will occasionally leave the car for without starting for a long period. What period?
  9. schja01
    schja01 Senior Member
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    What in the battery size for the gen 5 non prime Prius?
    Gokhan likes this.
  10. mva
    mva Member
    170
    100
    B.C. Canada
    2024 Prius Prime
    SE
    I disconnected my negative terminal when the car was left parked for 2 months. I ensured that the 12 volt battery had a good charge before disconnecting and the traction battery range was low for long term storage.
    on a previous vacation I left the car parked for a week without disconnecting the 12 volt and I had no issues.
  11. Gokhan
    6,663
    2,641
    Paramount CA
    All Gen 4 and Gen 5 Prius flavors use the EN LN1/BCI 140R/DIN H4 group size. The Uplus has side vents and a plug, so it can be used in Gen 5.
    Uplus EN LN1/BCI 140R/DIN H4 AGM battery on Amazon
    schja01 likes this.
  12. Gokhan
    6,663
    2,641
    Paramount CA
    It is better to connect a battery maintainer like the Noco Genius, as it has self-drain, but if you can’t, disconnecting it is better than leaving it connected.
  13. Mendel Leisk
    42,148
    It’s good if the only option, for a month or two, if the battery’s in good shape at the outset. I’d only go that route if I didn’t have a secure garage with AC outlet, for a charger hook up.
