Old gas in tank, what to do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aloe, Feb 3, 2024.
  1. Aloe
    Aloe Junior Member
    61
    Canada South
    3/4 of the gas in the tank is about a year old. It starts and runs fine before I added in 1/4 tank new gas in recent weeks (still runs fine).
    My final goal is that when the tank is next empty, I will put all new gas and gas stabilizer.
    The question is, what should I do at the moment? Car runs fine. Is there any risk to using the gas? I plan to go for a long drive and run it empty soon.
    If not, the only recourse I know is to pump it out, but AFAIK this cannot be done from the tank inlet. I can't imagine it will be cheap going to a mechanic for whatever they can do.
    #1 Aloe, Feb 3, 2024
    51,141
    if it's running fine, i would jus keep adding fresh gas as you use it.
    JohnPrius3005 likes this.
  3. Aloe
    Aloe Junior Member
    61
    Canada South
    Gas stabilizer only works on new gas. Should I not run it till almost empty instead of your suggestion to keep adding new gas as I go along?
  4. JC91006
    16,672
    8,518
    Takes way more than a year for gas to go bad. Just drive off the remaining gas and fill back up with some super unleaded
  5. PriusCamper
    PriusCamper Senior Member
    12,058
    4,893
    Pacific Northwest, USA
  6. Aloe
    Aloe Junior Member
    61
    Canada South
    I'm in Canada, It's 87 and some other higher octane. Super would be the highest octane? If that is the case, isn't higher octane also more ethanol mix? I understand higher octane has more cleaning properties.
  7. Mendel Leisk
    40,575
    In Canada Chevron 94 octane is straight gas. Check at the pump; there’s typically a decal saying that.
    how often are you not driving, and for how long? How many kms do you put on it, say in a year? It could be you don’t need to do anything special.
  8. PriusCamper
    12,058
    4,893
    Really? Are you sure?
    Down here in US we call it "no-ethanol" or "non-Ethanol" gas and you can only get it at a very small number of gas stations in only a few states.
  9. PriusCamper
    12,058
    4,893
    Incorrect... Even if Toyota makes that claim in their PluginPrius owners manual JDM has made it clear what the studies have shown:
    "The length of time fuel will remain useable in your gas tank is dependent on the fuel type. Regular gasoline has a shelf life of three to six months, while diesel can last up to a year before it begins to degrade." Ref: How Long Can Gas Sit in a Car Before it Goes Bad?
    Of course diluting old gas with new gas is probably the most common way people dispose of it.
    #9 PriusCamper, Feb 3, 2024
  10. Aloe
    Aloe Junior Member
    61
    Canada South
    Last year, about 200km (that 1/4 tank).It could and has been months in between drives. I'm using the company car most of the time now. I thought of selling it but if I change jobs, it's going to be a hassle to get another one. And once in a few month, I need it for work. Since I am keeping it, what do you suggest in terms of how far and often I should drive at a minimum?
    #10 Aloe, Feb 3, 2024
  11. Mendel Leisk
    40,575
    10 kms weekly, say 500k yearly? Keep it on a charger possible?
  12. Mendel Leisk
    40,575
    I was, but checking just now, looks like in the last year or so federal regulations nixed it, all levels have some ethanol.
  13. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    Just drive the dang car until you run out of gas if you want then pour in some fuel whatever it is you're going to be using and that'll be that pretty uneventful. Down here in the United States I run sheets blue fuel whatever that is 88 octane got ethanol in it blah blah blah been running it ever since it's been available never had a problem with a Prius and gasoline yet That's the least of the problems with the Prius is the gasoline everything else will fall around the car on a generation 3 but fuel will be the least of your problems and a generation two probably never thought of until the gas tank goes bad or something happens back there You don't hear fuel talked about all that much so you should run it out or close to it I drive my twos until the flashing pip is flashing and then add about 25 mi to that just because so I know when I pull into the gas station I'm close to fumes I put 10.9 gallons in my 11.1 gallon tank or something similar I'm stretching that bladder out like a pregnant woman in the morning.
    Pioneerscot likes this.
  14. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    I would not run it below a quarter tank, and refill each time with premium gas. After 3 or 4 cycles of this the percentage of old fuel is basically 0. Gas loses some of it's "bang" over time and also gets contaminated by moisture in the atmosphere. Not so much the latter with the prius fuel system though. Anyway, if your fuel has lost 25% of the bang when you refil with 3/4 of really good gas a few times you should be fine. I had an old motorhome, gas was close to 10 years old. It was a bear to start on that stuff but it would run. I diluted it using this system and after 3 cycles it started fine and ran great.
  15. bisco
    51,141
    I would not wait to drain most of the tank unless you’re going to do it all now.
    Otherwise, the gas just gets older and risk goes up.
    Mixing fresh gas every day or so is an antidote to stale fuel
  16. Mendel Leisk
    40,575
    Why would refilling with premium gas be better, say compared to regular? Not completely challenging this, but curious.
  17. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    My vote, since no drivability issue, continue to drive till empty, then only add a 1/4 tank, drive again to empty, then fill.
    I have no insights to Stabil et al and fuel staying in the tank a year.
    FWIW.
    I am guessing here, if there is no fuel tank drain plug it may be possible to remove the fuel line at the fuel injector rail so the fuel pump can be used to exit the fuel through this rail. No sure if you can "old school" siphon through the gas tank fill nozzle.
  18. mr_guy_mann
    mr_guy_mann Senior Member
    3,962
    1,911
    NJ-USA
    Well, general (unconfirmed) rumors have it that most premium grade gas has higher (better?) levels of detergent additives.
  19. Mendel Leisk
    40,575
    Higher octane is less prone to pre ignite fwiw.
  20. MCCOHENS
    252
    101
    Chalfont, PA
    My t
    My theory is averaging octane numbers. And also the theory that premium gas from certain suppliers has better cleaning chemicals. Sunoco 93 is my favorite, ignore the price and just use it once in a while. I have no scientific data on this.
