"Old" Gas in the Tank
Discussion in 'Gen 2 Prius Fuel Economy' started by Anonymous, Aug 9, 2005.
  1. Anonymous
    Anonymous Guest
    Sorry if this is a dumb question, but... Given how most people seem to wind up putting far less than 11.9g in at each fillup, that means there will be a few gallons of "old" gas and the rest "new" gas. Are the tank construction, gravity, and fluid dynamics such that the old gas is always the same gas, or does everything mix together? I guess I just wouldn't want the same gas sitting in the tank for months.
  2. wstander
    wstander New Member
    982
    Assuming that you always fill the tank completely, the 'swirl' of the new fuel as it enters the tank probably blends the 'old' fuel with the 'new'.
    I never considered this with automobile gas, only lawnmowers, chainsaws, etc., and of course, diesels in winter.
    Do you not drive for weeks on end or store a car for say, 12 months or so (when I was overseas, we just put some Stabilizer in the fuel tank and filled it full.)
  3. Anonymous
    Anonymous Guest
    No, I do drive at least a few times a week and fill up at least once a month. I was just wondering what was going on inside the tank.
    HPrimeAdvanced likes this.
  4. Jimmie Ray
    Jimmie Ray Junior Member
    33
    I bought a Prius that sat for a year. I just had a new hybrid battery installed tonight and the car will not stay running. The mechanic said it has bad gas in it. What should I do. I’m at a complete loss.
  5. JC91006
    16,470
    8,383
    Does the car stay in READY mode? READY showing on your dash and you see the speedometer at all times?
  6. bisco
    48,965
    are there any dash trouble lights on?
  7. Jimmie Ray
    33
    No. It starts and smells like old gas. Then it shuts down. I just put in a can of seafoam
  8. Jimmie Ray
    33
    No. It just shuts down. I just put a can of seafoam in it. And will try again tomorrow.
  9. bisco
    48,965
    when it shuts down, can you drive it?
  10. Jimmie Ray
    33
    No
  11. bisco
    48,965
    is there any gas in it?
  12. Jimmie Ray
    33
    Yes 7 gallons
  13. bisco
    48,965
    how much of that is old?
  14. Jimmie Ray
    33
  15. bisco
    48,965
    what is todd at tampa hybrids saying?
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,097
    5,809
    Columbia, SC
    So, if you place your foot on brake pedal and press the power button, the car goes into it's startup routine. The READY indicator lamp should illuminate almost immediately, and then about 10 seconds later, the engine will start. The engine runs for a short time and then turns off as part of the startup routine. Although the engine turns off, the car is still READY and can be driven at any time. You're saying that your car starts the engine, it turns off, but doesn't stay in READY and doesn't give any faults?
  17. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    It should be fine.
    But you could pump all the gas out (by removing the fuel line and running the fuel pump) and then refill with all new.
    Or try to see if you can get it to start using starter fluid.
    What is the state of charge of the hybrid battery?
    I would clean the MAF, the throttle body and sop up the excess oil on the intake in order to have a good clean starting point.
  18. padroo
    padroo Senior Member
    2,763
    2,250
    Your gas should be fine but if you want to remove it go to Harbor Freight and buy one of their cheap red pumps and pump the tank out, it is really easy to do.
    Multi-Use Transfer Pump
    It takes a while to use up the old gas in the fuel lines then it should run better.
  19. Jimmie Ray
    33
    I am not using him.
  20. TMR-JWAP
    6,097
    5,809
    Columbia, SC
    I'm confused. I read back through your original postings from October 2017. You mentioned a few times that all maintenance was done by the dealer, the car "runs like a top", etc.
    Has the car actually "run" (been driven) since you purchased it? Did you drive it home or tow it? What is your previous experience level with Prius vehicles? Can you respond to post 16?
    For some reason, I just have a gut feeling this is all due to misunderstanding how the car works.
