Oldest HV battery? also P3009 & transmission fluid
Discussion in 'Generation 1 Prius Discussion' started by kbbpll, May 26, 2021.
  1. kbbpll
    kbbpll Junior Member
    38
    26
    2002 Prius
    I'm curious, in general what is the oldest / highest mileage HV battery? Our March 2002 is now over 19 years old with a bit over 276000 miles on it. The HV battery has never been replaced or "serviced".
    I had the dreaded red triangle last week and the shop pulled a P3009 code - high voltage leak detected. Subsequently they could not duplicate the issue. One of the things they asked me was whether I had recently had the transmission fluid replaced. I said no. I looked this up, and one site says that a short can occur through old transmission fluid because it can become conductive. (It turns out the shop asked me about this they said because fluid spills could cause the short).
    I'd have to look up my service records, but it's probably been 100k miles or more since I had the trans fluid flushed and replaced. So I had them do that. The problem has not repeated in the week since. How likely is it that the trans fluid was really the problem, or can I expect transmission failure or HV battery failure in the near future?
    Otherwise it still runs great. I had the inverter coolant pump replaced last year, and the ignition coils and plugs replaced last year as well, but no other big issues.
    davecook89t, WHCSC and kenoarto like this.
  2. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    Out of curiosity, in what geographic location has the car spent most of its life? Garage kept or not? Letting a car sit regularly in the hot sun at a low latitude location is thought to reduce battery longevity.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,201
    5,897
    Columbia, SC
    The Gen 1 DTC is quite different from the Gen 2 with regard to P3009/P0AA6 codes.
    Gen 1 info here from a very reliable Prius source:
    2001-2003 Toyota Prius P3009
    dolj likes this.
  4. kbbpll
    38
    26
    2002 Prius
    Garage kept since purchase, Colorado (dry climate), 5500' altitude. I watched a DIY video and now I'm curious if the shop removed and cleaned the pan when they flushed it. In the video I saw, there was a lot of sludge in there. I'm mainly curious here whether the P3009 can actually occur because of a short through old transmission fluid.
    davecook89t likes this.
  5. dolj
    dolj Senior Member
    7,635
    3,852
    Wellington, New Zealand
    Do the test in the link TMR-JWAP posted in post #3. This will show you where to concentrate your efforts.
  6. kbbpll
    38
    26
    2002 Prius
    The issue has not recurred. If it does I will try to isolate it.
    dolj likes this.
