On Vacation
Discussion in 'Gen 2 Prius Main Forum' started by SalLema, Mar 4, 2009.
  1. SalLema
    SalLema Sal's Pride
    Palos Heights, IL
    I have a wonderful Black 2006 that is my Pride and Joy. I will be heading out of the country for a few weeks and wondered what I had to do to keep "Kit" from loosing his juice while I am away? Do I need to have Kit started weekly while I am gone?
  2. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    if you have the SKS, turn it off and you'll be fine.
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    For a minor fee, I'll drive Kit around for you.
    It's the least I can do for a fellow Prius owner.
    Have fun on vacation.
  4. Patrick Wong
    18,200
    6,472
    If a "few weeks" means more than three weeks, I suggest that you disconnect the 12V auxiliary battery - or else be prepared to jump it when you return. However, if you can get competent help who can make your Prius READY for 30 minutes at a time, then ask for this to be done every other week while you are gone.
    Enjoy your vacation!
  5. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Disable SKS and hopefully all will be fine when you return. If you intend to frequently be away for such times, consider using a "smart" battery tender like this one
    BatteryMINDer® Plus 12 Volt 1.33 Amp Charger-Maintainer-Conditioner (Desulfator) :: All :: Battery Chargers by BatteryMINDers.com
    The smart battery tenders can be left plugged in indefinetely with no danger of overcharging the battery. It's best to hook them directly to the 12 vdc battery
    Not sure I'd want somebody playing around with my Prius. Even a well meaning person can make a mistake, and put the car into Acc or Ig On instead of Ready. That's a sure way to discharge the battery
