One beep after car tuned off
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Feroze Sidhwa, Sep 1, 2013.
  1. Feroze Sidhwa
    Feroze Sidhwa New Member
    Every thing runs fine, when I turn the car off it beeps once.
    I had bought this car new, it never used to do that.
    Recently took it to dealership for oil change & service person said the beep should go away after oil chage.
    Had connected a CAN anayser did not see any error codes.
    Has anybody noticed this problem.
    Feroze
  2. fuzzy1
    10,175
    On my car, it means the sunroof is open. Does yours have a sunroof that isn't closing securely, or has a limit switch problem?
  3. Feroze Sidhwa
    No I do not have a sunroof
  4. rocketrob
    rocketrob Member
    104
    Los Angeles
    If it's the same as previous model of Prius, the beep means your smart key battery is low.
  5. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    Same thing happened to me on my 2008 Prius. One beep at shutdown was a low smart key fob battery.
