One headlight out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mysta2, May 17, 2014.
  1. mysta2
    mysta2 Junior Member
    My driver side headlight is out in my '08 touring (HID) I bought replacement bulbs on Priuschat recommendation. Swapped that one out, no change. Is the ballast next on the list?
    Also, this may be a coincidence. But that headlight assembly seems to be a bit leaky. After a rain a fair amount of condensation gets in there.
  2. Patrick Wong
    18,200
    6,471
    No coincidence, you should fix the leak or replace the headlight enclosure. That moisture probably caused damage to the ballast or corrosion in the connections.
  3. mysta2
    I'd like to repair the leak. Is there a particular type of silicone/ adhesive I should use in gluing them back up?
  4. Patrick Wong
    18,200
    6,471
  5. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
  6. Fifine
    Fifine Member
    106
    So Cal
    Hi Patrick
    In case you still receive this thread: is the ballast in the enclosure on headlight assembly attached by 4 screws?
    There's a DANGER label on this piece warning of "Shock, Burn" etc. Is it safe to remove to check for leak and water damage?
    Also, the Super Glue you recommended in Post #4 is a permanent "sealant", correct? I'm not sure if/why I may want to open the headlight assembly in the future??? But just in case, can I use a lithium based sealant instead?
    Thanks.
  7. Patrick Wong
    18,200
    6,471
    I haven't had a problem with the headlight ballast in my 2004 so I don't have personal experience with this. According to the exploded parts diagram in my repair manual, the four screws hold an access plate. Then it looks like there is a gasket for that plate and then two screws hold the ballast unit to the headlight housing.
    Yes, the warning label shows that you have HID headlights. I assume that the car will be IG-OFF, the headlight switch will be off, and you will remove the wiring harness connector to the headlight assembly before taking anything apart. If my assumption is correct then you have nothing to worry about with regards to high voltage.
    I don't have experience with the sealant that you mentioned.
  8. Fifine
    Fifine Member
    106
    So Cal
    The assembly is removed and many yards from the car :unsure:
    Just wanted to make sure there's no residual charge under that DANGER plate!!!
    Thanks again : )
