One More New Prius Owner
Discussion in 'Newbie Forum' started by fadedindigo, Aug 18, 2008.
  1. fadedindigo
    fadedindigo New Member
    I got my 2008 Prius with package 2 today. I only waited a week too because someone canceled their order and the dealer offered me the car when I called. Paid MSRP and it came in the color I wanted too! I had them install the "clear bra" and underbody coating because Minnesota salt and snow really eats your car.
    P.S. The SKS rules! I keep thinking I have to turn a key to take it out of the ignition after I park. :D
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    Congratulations!
    SKS is definitely the best option on the car, IMO. The only problem is that when you have to drive a different vehicle, you will resent having to deal with an old fashioned key. :D
  3. thepolarcrew
    thepolarcrew Senior Member
    4,426
    271
    North Dakota
    Start fumbling in the pocket. Man that sux!
  4. richard schumacher
    7,664
    1,045
    United States
    Sweet! But when did you last buy aftermarket undercoating? These days it can cause as many problems as it prevents.
  5. Courtney
    Courtney New Member
    25
    So. Cali
    Congratulations on your new car Indigo! The key system is interesting to get used to isn't it? But so much fun! The power button truly amused me as well! What a sweet deal to have such a short wait and only pay msrp! There are many here that envy you I'm sure! Have fun!
  6. fadedindigo
    i had undercoating done back in 2001 on my 01 acura integra. 7 harsh winters and no sign of rust to this day. haven't had any problems yet.
  7. dogfriend
    7,512
    1,189
    Carmichael, CA
    What is this rust that you speak of? :madgrin: :evil:
  8. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    :cheer2: Congratulations :cheer2:
    BTW I hope you wiped that stuff off of the bottom of your shoes before you got into your nice new Prius.
  9. richard schumacher
    7,664
    1,045
    United States
    Make sure that the undercoater didn't plug up or displace the A/C evaporator drain tube. Cleaning out all the chassis weep holes would also be prudent.
  10. dwreed3rd
    742
    Marietta, Ga
    Excellant point: Is there a list of of drain holes anywhere? If not is there any recommendation as to where to go to find out where they are?
  11. dogfriend
    7,512
    1,189
    Carmichael, CA
    I don't know of any list, but I would make sure the AC condensate drain line is clear (as Richard mentioned) and that the weep holes in the doors are clear. Water can get into the doors past the rubber seals at the bottom of the movable glass. Each door will have a least one or two holes or slots so that the water can drain out of the door.
  12. Patrick Wong
    18,200
    6,498
    Further, the cowl drains are located behind the front wheel openings. Gently pour some water into the cowl, one side at a time, and see where the water drains out of the body.
  13. dwreed3rd
    742
    Marietta, Ga
    Thank you guys. Lets see;
    1. A/C drain
    2. Door drains (1 or more per door)
    3. Cowl drains (1 behind each front wheel opening)
    4. There should be some in the door sills too.
    BTW these are good things to check on occasion w or w/o undercoating.
    Anything else anyone can think of to check for blockage after undercoating?
    I don't know may way around the site enough to know if there is a way to have a list somewhere that anyone could add to it. If not I think you could click on the "Quote" and add to it or I can go back and edit this post to add things and put "Addition" in "reason for editing".
