One side of brakes not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Logan_silva123, Oct 16, 2023.
  1. Logan_silva123
    Logan_silva123 New Member
    Massachusetts
    Couple days ago a wheel stud broke when removing a lug. So I go in, I take the the whole bracket, and caliper off in one piece, hang it up. Then not thinking, I hit the breaks to put it in neutral in order to fix the wheel stud. That closed the caliper of course and had trouble getting it all back together. Had to push it back open to fit it back over the rotor. Got it all back together but now I have abs, e break, and break system warning lights on. And it feels like the side I took apart is now not working at all or not as well, from feeling rotor temps. Does anyone have suggestions, I don’t wanna go to a shop and have them tell me it’s the whole abs module because I messed up when taking it apart
  2. ChapmanF
    19,008
    Start by getting the trouble codes from the brake system. If you don't have a scan tool that can do it, get them like this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Then we'll know more. If there was no brake fluid that escaped around the piston, things might not be too bad. If any did, you might have to revisit the way you got it all reassembled, and get some more fluid, and go through the bleed procedure.
  3. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    Did you crack the fitting on the caliper in order to squeeze it down or do whatever it is you did to get it back together?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Retrieve the codes as suggested. Given the description of events, I would expect to find a "hydraulic system malfunction" code for whichever front brake was removed.
    Basically that means that the brake control ecu "saw" low pressure at the disconnected brake, and interpreted it as a big fluid leak. If that is accurate, the ecu would set codes and keep the hydraulic valves for that brake closed.
  5. Logan_silva123
    Massachusetts
  6. Logan_silva123
    Massachusetts
    No didn’t damage the caliper or the break line at least that I can see
  7. Tombukt2
    13,848
    2,515
    Durham NC
    Crack meaning to open the line fitting to get the fluid to squirt out so you can squeeze the caliper did you open the zerk fitting the little silver thing?
