Only 29MPG for My Gen 2 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by dongfang, Feb 9, 2018.
  1. dongfang
    dongfang Junior Member
    36
    My 2007 Gen 2 Prius has 270K miles, and it is with me since 2013. It was running well and had average 46MPG (annual average).
    However, since last summer, after I drove it in 100F degree weather for 3 days (3 * 12 hours, the hottest three days in middle US) , the MPG became notable lower, and now it only reach 29MPG for today, while the weather is still above freezing point.
    I have checked:
    1. Tire pressure is not the problem,
    2. The spark plugs were replaced, and the throttle was cleaned recently.
    3. The engine is consuming oil for about 1.5 QT per 5000 miles
    4. Toyota TIS stream shows HV battery Internal Resistance R01~R14 are among 0.024~0.025ohm
    5. Sometime I can hear some noise that matching car speed, but that's not bearing noise, as I already replaced two bearings.
    Kindly, please share your point of view on why the MPG number is so low now? Anything else I should check?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    With a Gen2 at that mileage, my bet is you have a weak hv battery module.
    Some questions:
    • How fast do the bars for how full the battery is cycle?
    • Original hv battery?
    • Have you inspected the brakes to ensure they are not impinged?
    • Where in middle America are you located?
    I recently helped another member here that had low mpg (26-30) for a bit then had 2 failed modules in his battery pack:(.
    Got some modules and used the hybrid automotive Prolong equipment and it’s getting low 40s now:).
    Keep us posted (y).
  3. dongfang
    36
    Actually since I got this car in 2013, I always feel the ECU is not so "willing" to use the HV battery power, instead it requests ICE start often. I think this might be worse after that journey, but I don't have quantifiable data.
    Since I'm the 2nd owner, I'm not sure whether the dealer ever replaced the battery or not.
    I haven't checked the brakes, maybe I need find some video in youtube to do that.
    I'm in Seattle now. The journey I mentioned was driving this car from KY to it. During that days, the weather was so hot, and A/C was keeping running but can not reach the desire temperature, I'm wondering whether the HV battery was impacted because of that...
    However if it is HV battery issue, looks like the 14 HV blocks are still in same condition, unless I replace them all...
    51,141
    yeah, maybe a new battery is probably your best bet.
  5. milestoempty
    milestoempty Junior Member
    Annapolis
    Is there an easy way to test the battery without removing it?
  6. Prodigyplace
    12,405
    11,681
    Central Virginia
    I believe @TMR-JWAP & @ericbecky use some Android based software.
  7. dongfang
    36
    The HV battery each block's Internal Resistances and Voltages are the best data you need. Although purchasing a Bluetooth OBD+Andriod APP "Torque Pro" is enough to see these data, you may want to buy Toyota TIS Techstream which is much more powerful.
    Raytheeagle likes this.
  8. Prodigyplace
    12,405
    11,681
    Central Virginia
    TechStream is only legally available through a Toyota subscription though.
  9. Mendel Leisk
    40,576
    Feel the wheels right after a good drive; see if any feel hot.
    Prodigyplace likes this.
