Only 38 mpg right now
Discussion in 'Gen 3 Prius Fuel Economy' started by Frank MM, May 17, 2025 at 2:13 PM.
  1. Frank MM
    Frank MM Junior Member
    I have a 2011 Prius and I'm only getting 38mpg at the moment and I'm quite annoyed. See my post in the troubleshooting forum if you'd like and feel free to chime in.
    230,xxx miles on this bad boy and want to keep it going.
    Thanks all.
    Sincerely,
    Frank
    50,881
    could be the 12v, hybrid battery, worn engine, tyres, many different possibilities
  3. nicoj36
    nicoj36 Active Member
    518
    162
    Do the following:
    1. Clean your maf sensor
    2. Do a bottle of redline fuel treatment
    3. Do the reset on this video
    4. Enjoy your mpgs again.
  4. DirkAshburn
    DirkAshburn Member
    111
    44
    Virginia
    That's what I'm getting on my 2011 Prius as well.
  5. Grit
    Grit Senior Member
    6,390
    4,174
    Wilkes Land
    Without history of maintaince provided, it can just low tire pressure.
  6. DirkAshburn
    DirkAshburn Member
    111
    44
    Virginia
    I think its just a weak hybrid battery. I have 165k miles, quite a lot lower than his 230k but I'm guessing he has a lot more highway miles. I check my tire pressure every month, and brakes/etc are all fine. I get the same mpg, 38-39 consistently. My average speed is 23mph in my city commute. I've often thought of just replacing the battery but I think I'll just wait until it dies.
  7. ASRDogman
    ASRDogman Senior Member
    7,050
    3,692
    What brand/type of tires are you using? That does make a difference
