Only 40MPG on my 2010 Prius. Any ideas??
Discussion in 'Newbie Forum' started by afstudio, Nov 6, 2009.
  1. afstudio
    afstudio New Member
    San Rafael, CA
    My 2010 Prius is only a few months old and I'm averaging 41mpg. I take mostly short trips (15 minutes to work) but even if I take it for 1-2 hours it doesn't help that much for the average.
    Any ideas?
    Andrew
  2. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Andrew,
    I also drive a V model, and am averaging about 50 MPG. I do know that the short trips can impact mileage a little more than longer trips, but it sounds to me, it's a learning experience with the vehicle and you may be entering the power mode (red) area too often.
    It's technique, and you will learn as you go. I would suggest resetting your TRIP "B" before leaving your house each day on the way to work and see what your able to accomplish with different driving styles. You want to have a little lighter foot, and it sounds like you may be driving it just a little harder to suffer in the MPG range.
    On a 1 hour ride, reset trip "B" again and just try to keep it in the ECO area if you can on the MID. I don't know what mode your driving in, but experiment a little with ECO one day, PWR the next to see what your able to accomplish. There are many posts on here on the PULSE and GLIDE techniques. Maybe a good thing to read as well.
    Check your tire pressures as well. I am running 35/34 on my V.
    Keep trying and you should eventually get the feel for much better mileage. And if the car is new it's lower in the first few thousand miles anyway during break in.
    ;) Bob
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Andrew, yes short trips do kill the mileage but you might be able to get it up quite a bit. Read some of the threads in the GenIII fuel economy forum.
    There is a lot of discussion about tire pressures, I am of the opinion that higher pressures are good for mileage, tire wear, and handling. Most PriusV have 51 psi max tires (the Michelins are 44 psi) so you can put quite a bit of air in them. I am presently running 48 PSI in all four and have had good results. Check some of the threads on that subject to get both sides.
    Typically you should be getting in the mid to high 40s on the freeway and around 50 combined city/highway. It takes some practice though, I had to develop some new driving techniques which took a while.
  4. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Have you tried resetting the average then going for a hour long drive? If you have the same average of 40 on there and go for a drive you may be getting 55mpg on the drive but your display will only go up to 40.4.
  5. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    If you live in the hilly part of San Refael, you may expect in the low to mid 40s.
  6. Leadfoot
    Leadfoot Penny pincher
    45
    Southern California
    2014 Prius Plug-in
    We live in the hills and my wife takes plenty of short trips in her III, up & down the hill. It massacres the gas mileage. 45 on a good week with lots of longer trips. Most times right around 40 to 42, after accumulating about 300 miles.
  7. Acre
    Acre New Member
    104
    Woodside, CA
    What was your previous car? How close did it come to achieving the EPA estimate?
  8. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Same here. My normal commute is short, there are a lot of hills, and many stop signs and lights and I am only averaging in the low 40s. Recently, it has also been raining a lot, which also brings down the mileage. I get closer to 50 (calculated tank average) on long highway trips. Reset your odometer for different trips so you can see how the length of trip and driving conditions affect your mpg.
  9. Tideland Prius
    16,151
  10. jcherpack
    jcherpack Junior Member
    Pennsylvania
    Same model/year. Same story. Same mileage, mostly 40-41. Newish owner. Short commute - 18 min, local roads with lower speeds, some hills, little-to-no highway driving, yes a bit lead-foot sometimes (love that Power mode), am catching on to the engine brake. But coming from 18 mpg or less, I'm just so happy.
