Only front door speakers doesn't work.
Discussion in 'Gen 3 Prius Audio and Electronics' started by Kajus, May 19, 2020.
  1. Kajus
    Kajus Junior Member
    Hello everybody , have small issue with 2014 prius, its base model, no navi, no jbl system. PROBLEM-Only front door speakers doesn't work. Whole Dash panel was changed , and tweeters are jbl. Tweeters works, rear door speakers works, but no sound in front door speakers.I checked radio unit evrything is connected good. ANY IDEA WILL HELP, THANK YOU.
    52,396
    welcome!
    did you just acquire this vehicle?
  3. Kiwibird
    Kiwibird Junior Member
    56
    Sydney
    i-Tech
    To cut the story short, open the door trim, connect any speaker externally and check if it works. In my Prius gen2 my 4 speakers were shot and had to replace the whole lot, all working perfectly now
  4. hoffeck
    hoffeck Member
    Germany
    Take a look under your passenger seat if there is an amplifier installed. If so, check if this tension gets when you turn on the radio. I also do not have a JBL system but this amplifier only for the front door speakers.
