Only Getting 8 Gallons on Fill Up
Discussion in 'Gen 3 Prius Fuel Economy' started by mtneer79, Oct 7, 2010.
  1. mtneer79
    mtneer79 Junior Member
    Morgantown, WV
    I've had my 2010 Prius for about a month. My gas guage starts blinking and so I fill up the tank. Why am I only able to put 8 gallons in when it's supposed to have an 11.9 gallon tank?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Most people wouldn't see that as a problem. lol
    But seriously, Toyota left a lot of wiggle room in terms of gas. Guess they didn't want us to run out. You might want to use the DTE display. When that reaches 0 miles to empty, you should be able to put in 9.7 to 10 gallons in.
    Welcome aboard btw!
  3. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    There is a reserve of over 2 gallons when miles to empty is at 0. I do get more than 9 gallons though, so maybe it is not metering correctly and gives you even a bigger reserve.
  4. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    This happened to me: odd amounts of fuel at fill-up, slight inaccuracies with the gas gaug...all this after I had run over a particularly large piece of road debris....took it in and it turned out that the sensor inside the tank had been knocked loose and was sort of bobbing inside the tank. Consider having it checked out. All fixed now and all fill ups and tank usage reflect the commonly reported amounts
  5. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    How many fill-ups have you had over a month?
    I'd give it a couple of fill-ups.... I think it may adjust itself out next time you fill up.
    I am assuming you re-set the trip meter for at least A!
    Let us know how the car does the 2nd go around! My 1st fill up I got just about 8 gallons though I thought I would get more as well....
    My light didn't flash though!
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Get used to it. you going to enjoy the feeing!
    Mine, 8 gal = 400 Miles 2Pips left!
  7. Rdkam
    Rdkam Junior Member
    Seattle Area
    Happened to me today. Trip meter read 440 miles with gas gauge flashing and miles to empty 15. I pumped 9.7 gallons. This is my second tank, but with the mileage it's nearly 100 more miles to dry. I would like it to be a bit more accurate, but yes love the miles.
  8. jwads
    jwads New Member
    63
    Los Angeles CA
    Ya, accuracy would be nice in this thing. Ive found when I hit my bingo (0 mi remaining) I can easily get 50 more or so before I even get to 10gal fill up.
  9. macmaster05
    macmaster05 Senor Member
    4,050
    729
    The bladder has a capacity of 11.9 gallons but never fills up that much. Today I filled up 8.57 gallons from Empty after 468 miles. That's 54.6 mpg baby!
    So nothing unusual for you.
  10. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    The first 2 tanks of gas I put, I pump til the trigger disengages then I slowly top off til it spills. I was able to pump another 1.6 and 1.8 gallons into the tank. All the fill ups after that, I pump 1.5-1.6 gallons after the trigger disengages. I'm able to top off the tank without spills. The most gas I pumped into the tank was 12.2 gallons of fuel after 660 miles. I wanted to hit 700 miles but didn't risk running out of gas.
  11. macmaster05
    4,050
    729
    It's a bad idea to top off your tank, especially ad much as you're doing.
  12. cproaudio
    2,401
    759
    CA
  13. mtneer79
    Morgantown, WV
    Thanks everyone for your replies. I filled up again today. The miles to empty showed 0 and I had driven 460 miles. I was able to get 9.7 gallons into the tank. Does anyone typically continue to drive after the miles to empty shows 0? If so, it is safe to assume there is at least 1-2 gallons remaining?
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I have noticed that when the pump auto clicks off you can still
    get 2 gallons in the tank until it brims.
    al
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes it is OK. I think you can safely assume a gallon so about 50-55miles. I ran about 60+ miles after 0 but I can't remember now how many gallons I got into the tank. The main thing is not to run the car out of gas. It may cause damage to the pump and not even restart after putting gas in. Keep in mind having the car on an incline can cause the gas pickup to suck air if you are low on gas.
  16. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I have driven after the miles to empty = 0, pip flashing. It gives quite a thrill, never knowing how much gas you have. OK, it is a 11.9 gallon tank. From what you saw, you could get in another 2 gallons, but cut it to 1 gallon - 1.5 gallons. So, you could easily go another 50 miles after your fuel to empty is 0. Just means you don't have to rush to the gas station at that moment. The problem is, that if you keep putting it off or forgetting you will eventually run out of gas, thus defeating the purpose of the fuel to empty, flashing PIP, audio beep with flashing pip.
  17. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    There is no bladder in a 2010 Prius tank.
  18. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    It is annoying. I cannot get above about 500 miles estimated range after a full. I once hit "0 miles left". Reading other threads and basic math it's clear that you do have 1.5-2 gallons gas left but once you hit 0 miles you can pretty darn safely go another 50 miles. Although I'm too scared to :)
  19. macmaster05
    4,050
    729
  20. macmaster05
    4,050
    729
    once ur down to ur last pip u should be thinking where to get gas next. its stupid to try to push it especially if u have no idea what ur car is capable of as evidenced by threads like these.
