Only getting about 30 mpg 2010 Prius with sunroof
Discussion in 'Gen 3 Prius Fuel Economy' started by Prius2010driverdude, Nov 25, 2024.
Tags:
  1. Prius2010driverdude
    Prius2010driverdude New Member
    Los angeles
    Hello. I bought the car used. I recently had the main battery replaced. I thought this would improve the mpg but it hasn’t made a difference. The smaller battery was replaced about a year ago.
    thanks for your help and let me know if you need more details.
    51,019
    mileage?
    service records?
    is it a new oem hybrid battery?
    any trouble lights?
    air filter
    throttle body
    dragging brake
    plugs
    injectors
    coils
    tyres and pressure
  3. Prius2010driverdude
    Los angeles
    Hi. It’s a refurbished battery with I believe 30,000 miles on it. No warning lights. Everything else seems to be fine shocks, tires etc
  4. Eddie25
    Eddie25 Active Member
    481
    202
    MI
    First thing I would do is jack up the rear (there's a convenient rear-center jack point) so the tires were off the ground and test for wheel drag. Spin the wheels by hand and they should spin around a few times on their own, at least. There can be issues with calipers not retracting properly.
  5. bisco
    51,019
    driving style?
    terrain?
    climate?
  6. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    I got 30 mpg in my 76 Honda civic 5-speed w/1.5L engine. IMHO; you've got issues, so take it to a Prius specialist before dumping any more money into it. FWIW; most ICE cars of similar size, built after 2010 will do 35-40 mpg - without the added expense and weight of a hybrid system.
  7. Mendel Leisk
    40,457
    I think bisco meant the miles on the odometer. That’ll display for 30 seconds or so, every time you shut down.
  8. bisco
    51,019
    yeah, not expecting any more answers
