Only starts with jump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AHappyOwner, Nov 16, 2016.
  1. AHappyOwner
    AHappyOwner New Member
    Massachusetts, USA
    My 2013 Prius Two wouldn't start one day. The 12V battery was fine, but I needed to provide a jump at the front through the jump clip in the fuse box. A jump put on the battery in the trunk wouldn't work.
    It turns out there was damage to the 12V cable that goes from the battery in the trunk to the fuse box under the hood. The power wasn't making it forward. The cable is aluminum (instead of copper) and something damaged it.
    My local shop ran a new cable to replace the damaged cable, and everything worked.
    If you're having a similar problem, check the continuity from the battery to the fuse box.
    Timar and Mendel Leisk like this.
  2. Mendel Leisk
    40,574
    I wonder how that cable would break. (n)
    Maybe it's routed under the car and you ran over a curb?
  3. AHappyOwner
    Massachusetts, USA
    It's aluminum. If there is a scratch through the insulation, the aluminum will corrode. I think that's what happened.
  4. fuzzy1
    10,335
    Before replacing the whole cable, did the shop confirm that the fusible link was not blown?
  5. AHappyOwner
    Massachusetts, USA
    The link was fine.
  6. Mendel Leisk
    40,574
    Flood damage?
  7. AHappyOwner
    Massachusetts, USA
    I asked the shop what they saw. Something had clearly whacked the cable under the car. The plastic panel under the car was also banged up. Probably hit a rock or something on the road. I'm not the original owner, so it could have happened before I got it.
    fuzzy1 and Mendel Leisk like this.
