only took 5.5gal.to fill tank to full bars-only got 205 miles & 'low gas warning light' came on?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Mar 22, 2025.
  1. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I Filled the gas tank to full bars
    - [only took 5.5 Gal.]- to fill the tank to Full Bars
    -But after only driving 205 miles- the 'low gas warning light' came on???
    What could be the issues?
  2. Brian1954
    Brian1954 Senior Member
    2,219
    874
    South Central PA, USA
    This is a very common problem for the Gen 2 Prius. Do a search on this forum, and you will find your answer.
  3. Tombukt2
    Tombukt2 Senior Member
    13,003
    2,330
    Durham NC
    Well I'm going like 8.4 gallons for $345 mi something like that and when you say filling up to four bars or full bars what are you looking through the glass while you fill the car or are you filling it up till you till it shuts off or you filling it off till it shuts off and a few more squirts till you see the fuel at the top of the hole that you're putting the filler in? Generally I feel to the ladder all the way up until I can see the fuel right at that little hole I'm sticking the filler nozzle in and when the gas gets up to there everything is stopped that settles and it's right there about ready to fall out of where I put the cap on literally but I cap it off that's 8.4 gallons and I have driven about 345 355 miles and the display is telling me that I'm getting generally 40 mi to the gallon maybe 41.3. And now that's all changed it's jump back up 46 and a half after I change the fuel injectors like day before yesterday
    PriusPaddler likes this.
  4. Goodcitizen
    Goodcitizen Member
    74
    30
    Cali
    Your gas gauge may need recalibrating or your bladder shrank and you're screwed outside of replacing it.
    The gas guage reset chicken dance can be found on YouTube.
  5. bisco
    51,966
    i read that there is a trick to fooling the full bladder, i will search for it
  6. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    That does not "reset" the fuel gauge, it resets the inclination meters in the CM. The only real reason for doing that procedure is if you have just changed the CM.
    No one ever mentions that the EVAP system might be messed up, which is the most likely reason. One way to do that is to top off the fuel so it is right at the top of the filler neck, thereby flooding the charcoal canister with fuel. Don't do that on these cars.
    Brian1954 likes this.
  7. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    The Gen 2 Prius Prostate enlarges with age thus "reducing the volume of fluid" that the bladder can hold before the sensors kick in and give you a warning. You just have an 8.0 gallon tank now. It just is. You can buy a whole new gas tank and swap it out...not true for myself.
  8. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    How much did it take to refill?
  9. Tombukt2
    13,003
    2,330
    Durham NC
    From a flashing pip and 20.miles on that flash I religiously put in 8.4 gallons just before fuels on my foot.this is every other day in my world. Sometimes two different gen2 both hold same to the tenth
  10. Goodcitizen
    Goodcitizen Member
    74
    30
    Cali
    My gas gauge became real inaccurate. I reset the inclination meter per the service manual and it solved my issue. I had previously pulled my dash out and maybe it recalibrated improperly after power loss or something. My hud is original.
  11. bisco
    51,966
    Still can’t find that tip, will keep trying
  12. dolj
    dolj Senior Member
    8,450
    4,291
    By HUD, I assume you mean the combination meter. There is no HUD in the Gen 2.
    There is likely a correlation between you pulling the dash out and the inclination meters needing resetting. This is an example of when it is appropriate to reset the inclination meters.
    For most people with inaccurate fuel gauge readings, it usually points to the fuel sender (in the fuel tank) becoming flakey. This is easily tested to confirm the diagnosis. Unfortunately, for the NA model, the fix for this is a new fuel tank.
  13. bisco
    51,966
    Check the wheels to see if the brakes are dragging
  14. ski.dive
    964
    244
    I tried to fill up today and again, with only one bar left on the gauge.
    I could only get 5.5 gallons in the tank,
    I'm guessing that my Gas tank bladder has shrunk!!!
  15. Tombukt2
    13,003
    2,330
    Durham NC
    Where is the car in Vermont or Florida If you're in Florida should be starting to get warm now Just keep pounding gas in it and park it in the Sun My bladder has stretched out to the point where I can drop 8.4 gallons on high when I bought the car I was putting about 4.7 in it It would kick off I'm in North Carolina gets pretty hot I just kept filling the car up it's kind of parked in the sunny on my property and you know about two three months of doing that drive it a little run it on service calls in the summer It's hot as all get out outside like I say now I can drop 8.4 in it on full blast
  16. Goodcitizen
    Goodcitizen Member
    74
    30
    Cali
    Inclination Sensors.
    There are two inclination sensors located in the [fuel] meter ECU to
    detect vehicle longitudinal and latitudinal inclinations and to correct
    the fuel level calculation. Corrections are made by the signals from
    the inclination sensors and the ambient temperature sensor located
    in the fuel tank.
    The inclinometer must be reset if the customer complains that they
    can only pump a few gallons of gas into their tank or if they run out
    of gas with three or four bars left on the fuel meter. The inclinometer
    must also be reset if the Prius is refilled on an excessive slope or if
    the fuel gauge becomes inaccurate. Please refer to the Prius Repair
    Manual for the inclometer calibration procedure.
    This is from the Toyota tech training manual.
  17. Tideland Prius
    16,559
    Threads merged
    bisco and Brian1954 like this.
  18. dolj
    dolj Senior Member
    8,450
    4,291
    It sounds like a "Hail Mary" what have you got to lose approach, although the comment about if the car was filled up on an excessive slope is interesting. It would almost imply there is some kind of finessing of the sensor data going on.
    Anyway, if it works, as it did for you, then all well and good. It is just 95% of the feedback we get on here says it does not fix the problem.
  19. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
