Ooo... Actually Considerably Cheaper!
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Jun 10, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    I redid the calculations for how many cents per mile I'm getting on EV vs. gas, based upon:
    * Charging at home at Austin, TX tier-2 rates (500-1000KWh/month),
    * Including all fees at summer rates, except for the $10/month charge just to be an Austin-Energy customer,
    * 30 miles per charge,
    * $2.40 per gallon for gas,
    * 55MPG
    EV worked out considerably cheaper: 2.7c/mile vs. 4.4c/mile - about 38% cheaper, not ~20% cheaper as I'd previously calculated.
    That's without using Austin's $50/year all-you-can-charge buffet at ChargePoint stations around town.
    It's probably even less in the colder months, since we probably drop down to tier run without running the (home) air conditioner as much.
    Prius Prime in Austin: Good combination!
    iPhone ? Pro
    priuscatprimeguy likes this.
  2. Janice N
    Janice N Member
    51
    58
    Redwood City, CA
    I'm getting on average 1.6c/mi via 7c/kW charge point at work. Gas here is above $3/gal so it's a considerable savings.
    I won't be able to beat any records but it sure is fun to see 500mi on odometer with 5/8ths tank left.
    Thanks for doing the math.
    mr88cet and priuscatprimeguy like this.
  3. mr88cet
    2,311
    1,334
    Austin, TX
    Just FWIW...
    I should point out that I haven't really been paying attention to the price of gas around town, but that's roughly where it was last time I checked, which was ... a month or two ago.
    Best bet would still be home solar, in thinking...
    iPhone ? Pro
