Oops. Check Hybrid System after Intake Manifold/EGR Pipe Cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lightning Racer, Feb 23, 2016.
  1. Lightning Racer
    Lightning Racer Active Member
    239
    320
    Anchorage, Alaska
    I undertook this maintenance as a preventive measure, and to see if I could bump up the gas mileage a bit. After reassembly, when I try to start it up, the engine runs for 1-2 seconds, and stops, and I get a "Check Hybrid System" error. The engine will not restart. I'm trying to figure out where I screwed things up. Right now I might have to get it towed to a shop.
    I bought the Prius used last month, and it's at 151K miles. I've driven it about 800 miles since I've owned it. It had been running perfectly fine, with no check engine lights or symptoms. The scheduled maintenance items were all caught up. I had spark plugs changed, engine coolant changed, transaxle fluid changed at the famous Luscious Garage several week ago, and they said the car was in good shape. They actually recommended NOT cleaning the EGR pipe/manifold/throttle body or replacing the PCV valve if there were no symptoms or check engine lights. They said not to worry about it until symptoms occur - probably to save money. Maybe I should have listened to them, but I liked the ideal of things running perfectly.
    I used information from the "missing under light throttle" and other intake manifold cleaning threads and a couple pdfs on throttle body removal and intake manifold removal from the 2010 Toyota Prius Repair Manual that Mendel Leisk had attached to another thread. I generally followed the repair manual, except for not disconnecting stuff that didn't have to be disconnected, like the coolant hoses on the throttle body. That is to say, with the manual pdfs in front of me, I'm pretty sure I didn't forget to reconnect any connectors or hoses when reassembling.
    A moderate amount of dry, sooty carbon material was in the EGR pipe. I cleaned that out. The port leading to the EGR valve assembly was also filled with that dry soot, and I cleaned that out with a pipe cleaner, used dry, since I didn't want to create a sticky clog in the valve. I stuck a vacuum cleaner to that port afterwards, in case I had pushed soot back towards the valve with the pipe cleaner.
    The throttle body plate looked fairly clean already, but I did clean it up further with throttle body/intake manifold cleaner, and worked the plate open/close quite a bit while doing so (not sure that would cause a problem). There was oil visible in the intake manifold under the throttle body. I soaked that up with paper towels.
    The main EGR passage in the intake manifold had dry sooty material on the side that the EGR pipe attaches to, and transitioned to oily sludge on the far end, though there wasn't a complete blockage. I cleaned the main EGR passage and the four smaller passages out with throttle body cleaner and pipe cleaners. The interior of the intake manifold was oily, so I cleaned that up best I could with throttle body/intake manifold cleaner and wiping through the openings with rags. I also swished the throttle body cleaner around the inside of the intake manifold by rocking and turning and flipping it around. At some point, I realized that there was a sensor still attached to the intake manifold immediately adjacent to the throttle body, and became concerned that I was contaminating it. I removed the sensor, and it was oily and probably covered with throttle body cleaner too, so I sprayed it directly with throttle body cleaner to clean it further. I figured it had probably been covered in oil before like everything else in there, so no harm done. But this is one of the main things that I suspect now as to causing the problem. I let it air dry (though maybe 90% dry) and put it back on the intake manifold.
    The engine side was also oily, so I cleaned that up pretty well with a rag soaked in throttle body cleaner. I did reach in as far as I could get my fingers, and did touch the injectors, but I don't think I left any oil on them - I didn't that reach far in when getting the bulk of the oil out, just when cleaning the black deposits.
    With the intake off, I replaced the PCV valve. It was oily on both ends, but was still clicked when shook. I also cleaned the oil out of the rubber hose that goes from the PCV valve to the intake manifold.
    After reassembly, I started the car. After the engine ran for 1-2 seconds, it stopped and I got a Check Hybrid System warning. I kept driving on EV for 3 blocks before I realized that the engine wasn't going to restart, so I turned around and drove back home before the battery died. I think it has 1 or 2 bars now.
    I have an ODBII bluetooth thing installed that I hadn't played around with much. I have a Windows phone, so I had OBD Auto Doctor (free version) installed. I hadn't found it useful until now. After the Check Hybrid System error occurred, I paid $10 for the app upgrade to be able to clear DTCs with it. I then followed the procedure in the Repair Manual for what to do after throttle body reassembly: a) disconnect cable from negative battery terminal, wait 60 seconds and reconnect, b) clear DTCs with OBD Auto Doctor (instead of Techstream), c) set vehicle to inspection mode (used the 2x accelerator pedal in P, 2x accelerator in N, 2x accelerator in P method). In inspection mode, I get the same problem: the engine runs for 1-2 seconds and then stops and I get the Check Hybrid System error. I disconnected the battery 2-3 times and tried this several times, only the last time in inspection mode.
    Theses are the DTCs under confirmed and pending:
    P0123 Throttle/pedal position sensor/Switch "A" circuit high
    P2135 Throttle/pedal position sensor/Switch "A"/"B" voltage correlation
    P2135 Throttle position Sensor 1-2 correlation
    These DTCs are under permanent:
    P0102 Mass or volume flow "A" circuit low
    P0113 intake air Temperature Sensor 1 circuit high (bank 1)
    Can anyone provide suggestions on what to do next? What is that sensor next to the throttle body that I was playing with - maybe the intake air temperature sensor? I can't find a part of that name on the Toyota Online Parts catalog. I'm in San Jose, not Alaska at this time. Anyone local that can help? Or is there a close recommended shop I can get it towed to. The various garages on Winfield Blvd are fairly close.
  2. Lightning Racer
    239
    320
    Anchorage, Alaska
    DOH! I visualized how I reassembled everything last night and realized that I might not have plugged the big connector back into the throttle body. I went out to look at the car, and, sure enough, that was it. I was reassembling outside in the dark by headlamp, so I missed that, and I missed that in the repair manual pdf.
    Now the car is running better than ever. I haven't been keeping good records, but I think I had only been averaging about 45 mpg in the ~800 miles that I've had the car, with semi-hypermiling required to get about 49 mpg. My best was on the drive home from Alameda to SF to San Jose the day I bought it, when I recorded 57.7 mpg (MFD) for the very conservative/hypermiling first drive. I had attributed the lower mileage to my shorter trip lengths in general, but I knew the car should have been capable of better. Now after yesterday's work and plugging in that connector to the throttle body, I reset the trip odometer and drove the car around Almaden neighborhood in San Jose. This was after warmup, but I was seeing the average mpg go from mid-60s to 75 mpg on the flatter parts, and it dropped down to 58 mpg average overall for 6 miles after driving through some hilly areas. Seeing 60s and 70s on the display was unheard for me with this car and even over about 50 mpg was rare and only seen once for that first drive. Now it's probably at least 10 mpg better than I would have seen for that trip before all that work. Awesome.
    #2 Lightning Racer, Feb 23, 2016
  3. Rebound
    Rebound Senior Member
    3,972
    2,627
    Portland, OR
    Glad it ended up so well!
    Interesting that they changed the engine coolant but not the inverter coolant. Same fluid, but separate cooling system.
    The inverter coolant is easier to change than the engine coolant. They're both pretty easy, really.
    How are the brake pads at 150K miles?
  4. Lightning Racer
    239
    320
    Anchorage, Alaska
    Luscious Garage suggested inverter coolant too, but I declined because it was changed when a new IPM was installed in the inverter at 127K.
    I noticed a sharp decrease in documented front pad thickness when I was carefully going over the maintenance records in the Toyota Owner's site, so I wasn't surprised when front pads were gone. A local shop put in new front pads, turned the front rotors, and lubed both front and back brakes. Back pads are fine. The sharp decrease from an initially slow decrease suggests that maybe the front brakes started dragging or something, all before I owned the car of course. I know it's more common for the rear brake sliding pins to lose lubrication, but that's my guess.
  5. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Seems to me like you are going to be one of those people with a 300k mile Prius, good luck.
    Lightning Racer likes this.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,691
    Bay Area
    I'm glad everything ended well for you. I would hate to cause a problem when everything was running fine.
  7. Lightning Racer
    239
    320
    Anchorage, Alaska
    Yes, I'm getting it into tip-top condition for a car with 151K. That was the plan from the start - looking for a high mileage car with a lot of life left to keep it lower cost. I have a checklist of stuff from very minor to bigger that I've done on the car, and I've gotten about 30 things checked off so far. All the mechanical stuff is now done. All that is left is cosmetic like touching up paint scratches and polishing the headlights.
    My driving mileage is generally low, so I probably won't hit 300K unless my future commute or habits change, but I'm probably going to keep this Prius for a relatively long time. My other car is a 1996 Subaru that I bought in 2000 with 137K miles, and it only has about 207K miles on it now.
    Thanks. I had that thought briefly before I started, but wasn't really regretting anything. I knew that whatever was wrong was probably not a costly thing to fix. The seemingly random/unrelated to my work DTCs made me think that maybe I did leave something unplugged, so I starting visualizing what I had done and not done and figured it out in my head before even opening up the hood again. I should have had that thought process before posting here. :)
    Based on the Toyota owner's site, I knew the previous owner had brought the car into the dealer complaining that it was only getting 35 mpg at 149K only 1,000 miles before selling the car to me. To pass smog, he need to replace the MAF, purge valve, and A/F sensor. That brought it up to the about 45 mpg that I have been getting. The spark plug change ended up not helping the gas mileage. Based on the stuff I've been reading on Priuschat, I figured that at 151K miles even without obvious symptoms like knocking/hesistation, etc., the EGR, intake manifold, and PCV were probably also filled with soot and greasy slop to some degree, and therefore the likely culprits for the still lower gas mileage. That seems to have been true. I just joined fuelly to track gas mileage now that it seems to be pretty respectable.
  8. NutzAboutBolts
    1,601
    1,691
    Bay Area
    nice work, the only thing you'll have to worry about is the HV battery going out on you. We had a customer who came in with a 2010 Prius with 195k miles who needed his HV battery replaced because it died on him. Lets hope it last longer than that :) good luck! and enjoy the high gas mileage.
  9. Lightning Racer
    239
    320
    Anchorage, Alaska
    Oh, that seems to be on the low mileage side. There isn't much talk about HV batteries in the Gen3 forums yet. I figure that even with a HV battery change, I'm way ahead buying used. My Prius is a IV with the Solar package, so the original owner probably paid $30K+ at the time, plus what he paid to keep it running and repaired. After my fixing it up, it will be a very similar visual and mechanical experience for the next 5 years to what the original owner experienced during his 5 years. And it will have cost me in the $9K range for the purchase and initial fixing-it-up-best-I-can stage. My operating costs should be similar to the original owner for the most part, except maybe an HV battery. But the original owner paid about $1400 at the dealer just to get it to pass smog check for me, so that's about half an HV battery there. He probably could have saved a lot going to an independent shop like Luscious... or doing some of the stuff himself. And after 5 more years, my car will probably still be worth around $5K? judging by 2005 Prius with around 200K miles.
    For estimating purposes, I have the HV battery lasting about 10 years or 200K-300K+ miles, whichever comes first, so I think it should be good for about 5 more years with my lower mileage driving, but I won't complain too much whenever it fails.
    I did not pick up on the oil consumption threads before buying, so I hope I don't and won't have that problem. Head gasket replacement sounds expensive. So far, I haven't noticed oil consumption. I'm used to checking oil in my Subie, that is of a vintage that doesn't have head gasket problems, but has oil leaks of lesser concern - so I'll keep up that habit.
    #9 Lightning Racer, Feb 24, 2016
  10. Mendel Leisk
    40,586
    That sensor on the intake manifold, that you were concerned about, is likely the Mass Air Flow sensor (MAF). It is fragile/sensitive, supposed to be cleaned with a MAF cleaner. Most auto supply stores have it; I believe it's sim to carb cleaner but cleaner, leaves no residue. Supposedly pure grain alcohol will also work.
    At this juncture, with everything working, maybe just leave it as is, and research the MAF sensor. I believe access is easy, disconnect it's clip (the one that was causing you to get the warnings?) and then unbolt and remove the MAF sensor housing.
  11. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    The MAF is up on the air filter cover right where it meets the air intake. The sensor in question is the Vacuum Pressure Sensor or Absolute Pressure Sensor. I pulled mine and set it aside while scrubbing the IM and hit it with MAF cleaner on reinstall. Caution with it is a good idea as it's ~$200 new, although I don't ever recall seeing a reported issue with one...
    2010 Toyota Prius Base 1.8L ELECTRIC/GAS Automatic CVT. #8942147010: Manifold Absolute Pressure Sensor
    Lightning Racer and Mendel Leisk like this.
  12. Rebound
    3,972
    2,627
    Portland, OR
    Wow. I didn't even realize Prius now have to pass smog.
  13. Lightning Racer
    239
    320
    Anchorage, Alaska
    Well the first 4 years of a car is exempt, but afterwards Prii do have to pass smog since Spring of 2015 in California. The techs plug into the OBD and do a visual check of the emissions system (check the gas cap and ?). The check engine light can't be on, and all DTCs and readiness codes have to be clear.
    The seller of my car had the check engine light come on before doing the smog and then again before doing the recheck. So that meant a couple trips to the dealer for him, and several days of driving afterwards each time so that the readiness codes would clear.
  14. Lightning Racer
    239
    320
    Anchorage, Alaska
    Yup, I knew where the MAF was to start. It's in a very clean location and sees only clean air. The vacuum pressure sensor is in a place that gets very oily in Prii, so hitting it with throttle body/intake cleaner turned out to be perfectly OK.
  15. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Yeah.. they started that about 2 years ago. A victim of our own success. So many hybrids sold meant the state wasn't getting as much revenue relative to car sales as in years past.
  16. thomassurdi
    thomassurdi Member
    70
    84
    Gainesville fl
    I hope this is the right place to a ask this but I’m having issues after doing this same job. I took my air box out and removed the throttle body, cleaned it and then took off the EFR pipe and removed the intake manifold. Cleaned them both and put it all back together. I was going to do my spark plugs while I had the wiper assembly off, but I had the wrong socket so I figured since everything was put together engine wise except the wiper so that maybe I could drive down to her road and grab one. Well the car was making loud noises and shaking so I slowly drove it back to my driveway. After looking at my work I realized that i had forgotten to plug the the MAF plug back in. I did that and I put the wipers back on hoping it wouldn’t solve my problems, but now I’m getting a check hybrid system warning, also a check PCS system warming, a check engine light and a triangle. The car turns on but Thebes has engine s reman tough and shuts off loudly with a shaking feeling and then i get the warnings. It does drive, but I haven’t tried to take it far from the driveway. Any timely suggestion or advice would be greatly appreciated.
  17. Mendel Leisk
    40,586
    I was thinking once you plugged MAF sensor back in you'd be out of the woods, with 4~5 more starts the Check Engine Light would go out on it's own. But with it continuing to run rough, maybe not.
    How did you clean the throttle body: just a carb cleaner dampened cloth, or directly spray? The latter's been know to cause problems. Also, did you spray the MAF sensor with anything, say other than proscribed MAF sensor cleaner?
  18. thomassurdi
    thomassurdi Member
    70
    84
    Gainesville fl
    I didn’t clean the sensor this time but when I didn’t did alway with MAF cleaner. I cleaned the throttle body with throttle body cleaner.
    After a double check everything is put together correctly. I did notice however that one of the female copper pieces inside the plug for the throttle body is missing. Not sure if it was ever there, but I wonder if it was lost while I was trying to get the plug off. There are 4 male copper inserts that plug into those, but one of them would not be touching copper so maybe it’s malfunctioning. That could explain why the entire air box is shaking when the gas engine starts up. Really not sure how I would hold go above about focing that replace the plug?!
  19. thomassurdi
    thomassurdi Member
    70
    84
    Gainesville fl
    Ok, I'm doubting that the plug is the issue. I just took the car around the block. It drives fine. Actually it drives great when accelerating. It just idles rough with the gas engine on. Maybe it just needs to burn off some excess crud or hastily applied brake cleaner that may have gotten somewhere that it doesnt like crud or cleaner to be. Might be a good idea to go back in and clean the MAF sensor again just to be thorough. I understand that even a wayward speck of dust can be enough for that thing to get angry at you. The check hybrid system and check PCS warnings are gone. Fingers crossed on that. I still have a check engine light so ill go have that checked out tomorrow. If its just a leftover code from the MAF not being plugged in ill have it cleared and assume something is just dirty. I guess I just freaked out when I saw the hybrid system warning and everything going haywire after I half expected it to fire up and run like new.
  20. thomassurdi
    thomassurdi Member
    70
    84
    Gainesville fl
    Well, things have taken a turn for the worse. I decided to drive the car around the block again to see if it would burn off some cleaner or something and it seemed to be running fine, with the iccasional hard idle, then suddenly the check hybrid system warning and the orange triangle came on so I used all the juice I had to get the car to my driveway but I only mad with rar enough that the car is stuck out in the road with just the Jose up the driveway, and it’s dead. Now I can’t punt it on drive or neutral and I’m gonna have to put a sign on it so my neighbors will drive around it. Could I have somehow shorted out my traction battery, or is it more likely the 12v battery? The dome lights come on so I would assume that the 12v is working. I’m worried it’s the big one. Somebody please help. I don’t know how the heck a manifold cleaning could turn into this much of a mess. I need my car for work and now I have no idea what to do. I’m hoping discount auto parts can let me borrow a meter so I can’t read the codes. Otherwise I’m assuming I’ll have to have it towed to a shop.
