Open hatch beep
Discussion in 'Gen 3 Prius Main Forum' started by bokone, Nov 20, 2009.
  1. bokone
    bokone Junior Member
    25
    Columbus, OH
    I was carrying a large item yesterday and driving with the hatch open. I expected it to alert me to that in much the same way the seat belt alarm would have...but no. It just keeps beeping (it does however, stop while stopped). Is there a user defined "thing" to turn off the door ajar beep or at least make it a short series? I'm not really interested in pulling the fuse each time, but I don't drive this way often either. Thanks.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Someone needs to make an adjustable strap that can be locked into the tailgate latch and the other end hooks onto the hoop the latch normally engages. This can be used to carry large items with the hatch open. The strap could be marketed to most car owners as most have the same catch system. Having the catch in the latched position will (I think) keep the warning from beeping.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    We can market it under the CO (carbon monoxide) brand name. It should be blue.
    Tom
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Good one Tom. Do note that once the cat system is warm, no CO comes out of the exhaust pipe. The cat. converts it to CO2. ;)
    But it's a valid thing to take steps to avoid.
  5. patsparks
    10,664
    567
    It shouldn't bother you once you fall asleep.
  6. BeakerTX
    BeakerTX Junior Member
    23
    San Antonio, TX
    Great idea.....and it already exists and I own one. Although, I can't find a link for it at the moment. I haven't tested it with a Prius and I don't know if it will stop the beeping, but it does work exactly as you explained it.
  7. drew2fast
    drew2fast New Member
    GSO
    Quick hack/fix to silence hatch beep in Gen 3 (2015)
    I had to transport a door for a friend and the incessant beeping drove me crazy. I search but couldn't find a fix.
    Some said there was a button you had to press, but couldn't find one. I studied the hatch hook, it's a simple U shaped piece of metal. First i bent a long screw in the shape, stuck it in the latch hatch, and the light went out went out in the hatch area. Note, you have to press it all the way in, and it LOCKS in place. You have to press the hatch release button, and it will release it, actually it shot it out. I wasn't sure where to store this bent screw, so I went looking for hooks. and I found a hook with an eye on the other end of it. Now, I have it secured to the tie down in at the back of the prius with a piece of rope. The rope is just long enough to put it in the hatch latch.
    No more beeping. You can probably find one similar at local hardware store.
  8. Mendel Leisk
    38,728
    Yeah, mimic the shape of the hatch hook and you're in business. I've never yet needed to do this, but I tested with a carabiner of roughly the same dimensions, works great. Also gives you something to tie cord, to hold down the hatch. Short pieces of the plumbing pipe foam insulation are handy too, the kind with longitudinal slits. Push the tubing onto the lower hatch edge, to protect it.
  9. drew2fast
    GSO
    Here are pics for ideas of my hatch beep fix.
    Nickod and Mendel Leisk like this.
  10. drew2fast
    GSO
    I found a carabiner I had..but it's a bit thick. The other hooks are literally shot out, but my carabiner has to be pulled out of the latch.
  11. Mendel Leisk
    38,728
    Look for a carabiner roughly the same size as hatch tang:
    In place. You can hear the locking mechanism engage on it. As far as the car is concerned, the hatch is closed, there'll be no beep, and courtesy lights go out. To release the carabiner, press hatch release and pull up:
    Plumbing pipe insulation, to protect hatch edge, from whatever you've got loaded:
    #11 Mendel Leisk, Jun 11, 2017
    xliderider likes this.
